water pump shaft, does anyone know the diameter of both ends
Just fitting a new water pump supplied and the diameter of the new shaft at the pulley end has increased by .025 on the new pump to 0.502 from 0.475. does anyone know of the original lotus specor can measure the shaft at both ends for me.
Cheers Neal
Cheers Neal
IF EVERYTHING SEEMS TO BE GOING WELL, YOU HAVE OBVIOUSLY OVERLOOKED
SOMETHING.
SOMETHING.
- Apx
Thanks you've answered a question and i have brought a new pulley flange, mine is undersize by 25 thou.. The engine appears untouched since the 1970s and is the original engine for the car so i suppose if its not had a water pump and ancillaries since 1983 then thats how it was made.
SOMETHING.
SOMETHING.
- Apx
