Problem with Crankcase Ventillation
I have an engine with a Weber intake welded to a Stromberg head. Have no Idea where it came from, or who made the modification. Looks nothing like I have ever seen before.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
You don't really need a catch tank either by the way if you are using the kent separator because the separator prevents most if not all of the oil from being vented together with the blowby fumes.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Put a catch tank on the end and you will see that is far from the case, I had a brass cock on the bottom of mine on my X/flow westfield to recover the very clean oil such was its quantity, it definitely gets exponentially worse with tuning and higher revs, perhaps a standard unmodified engine would be minimal.
- Chancer
oldelanman wrote:The Kent breather you removed is probably baffled inside to catch the oil thrown up from the jackshaft fuel pump lobe, does the Burton elbow have a baffle inside ? Burton also sell a blanking plate with a deflector attached to prevent similar problems occurring with the standard breather system if the fuel pump is removed to fit an electric pump.
http://www.burtonpower.com/fuel-pump-bl ... fp281.html
My engine builder made one of these blanking plates with a deflector (I have an electric fuel pump) as the TC engine in my S1 has a metal vent tube that runs from the engine along side the transmission to the street. Nothing but a rubber elbow from the engine to the tube and two attachment points. No baffled box. He said without the deflector I would have oil pouring out the vent tube all the time. After three years of driving I can tell you there is very little oil coming out of that tube.
My track Exige S had an elaborate baffled vent system that went to a catch can. Without the baffles the catch can would fill with oil after every track session.
Last edited by Certified Lotus on Wed May 09, 2018 7:37 pm, edited 1 time in total.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
I must admit I find the whole idea of catch tanks a bit strange. Bit of a boy racer add on in my opinion. If you have a properly designed separator and ventilation system you shouldn't need one, any oil separated out is returned to the crankcase.
No road car ex-factory ever has a catch tank no matter how exotic or high performance!
- 2cams70
2cams70 wrote:I must admit I find the whole idea of catch tanks a bit strange. Bit of a boy racer add on in my opinion. If you have a properly designed separator and ventilation system you shouldn't need one, any oil separated out is returned to the crankcase.
it is not that obvious to me to get a "properly designed separator and ventilation system", esp. considering the possibility of an engine failure that increases blow back or otherwise blows with the effect of pushing more vapours out (head gasket leak etc) - and since these days any oil on the tarmac results in fees to pay for the cleaning, I will install a catch tank to be on the safe side. It also would help to track what's going on inside by checking regularly what is added to the tank.
I still will give a try at making up a separator hoping to minimize the amount ending up in the tank, and I'm planning to do that with an aluminium tube filled with steel wool and hopefully long and cool enough to condensate most of the vapors going up. The separator tube will be installed going up so that the condensates should be able to make it back to the crank during throttle off moments, and will have a brass mesh at the bottom to keep eventual small parts of the steel wool to fall in the crank (I may add a magnet to be on the safe side...).
not done yet, but reasonably high on the todo list to be tried this year
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Admittedly all modern road cars have closed crankcase ventilation systems. It would be interesting to know what system F1 engines use.
- 2cams70
The Burtons type 90deg breather gets oil thrown at it by the shaft that drives the distributor and oil pump, this then flows down the pipe, which is why the Ford type breather box has inlet and outlet offset and a plate running horizontally through it to stop oil travelling up.
You need a deflector to stop the oil being thrown up if you wish to use the Burton breather outlet. Ordinarily they are used with fuel pump blanking plate that has on a plate that deflects the oil.
V
V
- vstibbard
2cams70 wrote:If you have a properly designed separator and ventilation system you shouldn't need one, any oil separated out is returned to the crankcase.
'If' and 'properly' being the key words here.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Users browsing this forum: smiths everest and 17 guests
