Water return hose
• Page 3 of 3 • 1, 2, 3
Well, finally finished the front suspension and had a brief road test. Unfortunately, the gauge doesn't budge so I suspect I fractured the tube somewhere along the process of removing it and replacing the union. Who's been down this road and can advise on what I'm in for? Not really ready for a dash out job but suspect that is where I'm headed. Any tips or guidance for repair or replacement?
Any non-invasive substitutes I can use while fixing this issue?
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
Confirm it can make a reading by boiling up a pan of water alongside the car, with the bulb inserted, prior to contemplating gauge removal.
'72 Sprint
'72 Sprint
- richardcox_lotus
Thanks Richard. It failed the boil test, so on to plan b. It turns out that Holden carries a nice replica with the correct scale and matching font to the Smiths unit in my S4, so I ordered one thinking it would be good to have a proper back-up and with plans to have the original redone with other gauges when I get around to a more complete renovation.
Shipping was unbelievably quick so got it installed today, but will be next weekend or so before I have time to give it a field test.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
It's better to leave the brass adapter in the Head, put a Spanner to stop it rotating and unscrew the outer Nut.
The Temp bulb should slide into Adapter so you do not twist the Capillary Temp Tube. If you unscrew the Adapter in the Head without removing the Temp Bulb first you will twist and damage the Capillary Tube.
- alan.barker
Users browsing this forum: RichardHawkins and 19 guests
