+2S Engine removal to fix oil leaks
• Page 2 of 4 • 1, 2, 3, 4
It is certainly possible to remove the engine and gearbox as a single unit .... just a pain to do it that way IMHO... much easier to split the engine and gear box. Refitting the engine to the gear box in situ needs care but is easy to do if done with care.
i.e.
centre the clutch plate carefully using a suitable alignment tool with the flywheel pilot bearing
ensure the engine and gear box shafts are aligned and parallel
slide the engine onto the gear box shaft and jiggle until the splines engage
a couple of long bolts help to pull the engine and gear box together but do it carefully and don't use excess force on the bolts
other prefer other ways but just my 40 years and many many engine changes of experience worth
i.e.
I won't be challenging your wisdom!
As I am some way away from actually doing this (still got to fix that suspension mount spindle - a hitch already occurred), I will give it some more thought. If I can get to the bell housing bolts easily enough (have not tried yet, and of course there is the issue of not being as flexible as I used to be) then that would be the way to go, for sure.
But I may attempt to remove it all as one, just to see how easy / hard it is. In any case, I need to disconnect the propshaft, so I may as well try..
JonB - Coveted Fifth Gear
A couple more questions, if I may...
- My engine has a sort of plate attached to the back that covers the back of the head. It means that accessing the top bolts for the bell housing is nigh on impossible with it in situ. Can't see it on the parts diagram, is it standard?
- I've read that the gearbox leaks fluid through the rear when you tilt it. Does it not have a proper lipped oil seal? Again, not shown on the parts diagram.
If you slacken the two top bell housing bolts a couple of turns it will pull out
If you are leaving the box In when removing the engine it will not leak otherwise yes.
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
The 4 speed box has a sliding spline on its output shaft that comes out when you remove it so it leaks all its oil out. The 5 speed has a fixed output shaft so it does not.
The plate may be part of the radio noise suppression system fitted on some cars. There was alos a top plate that covered the spark plug well.
If you have the engine mounts split a engine supported it will move forward slightly allowing that bit more access to get at the bolts. Same true of reinstalling, do up your bellhousing from above and below before sitting back into final postion. Good quality open ended spanner and even an extension tube to slacken.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
rgh0 wrote: The 5 speed has a fixed output shaft so it does not.
But it can leak from the geartstick hole if you aren't careful. I had this issue when pulling the box out far enough to get to the prop shaft bolts. So less of an issue with Spyder chassis.
Good opportunity to drain box and fill with redline...
- mbell
Here is a picture of the plate I was talking about.
I can't get at the bell housing top bolts with it in place - or, I need to undo all the mounts, take the propshaft flange bolts off, disconnect the reverse light switch wires and clutch pipe, then move the engine & gearbox forward. This may give enough access.
Speaking of leaks, I noticed the oil cap is leaking. A new rubber seal is peanuts (about ?3) but I thought I'd take the old one out and have a look at it. It's got an indentation in it where the lip of the cam cover has been pressing against it. Seemed I could flip the seal over and get some more life out of it, so I tried it. We'll see if it makes any difference!
Jon, if the plate is aluminium, it is, as Rohan suggests, probably part of the factory radio suppression system. It should have slotted holes as Hawskfield says, so you only need to just slacken the bolts & it should pull out. My +2 has the plate, & whilst it is a bit tight, there is enough room to get a long spanner in there. It is a job made much easier if you remove the head before engine removal, but can be done without. In reality, there's only very little more room without the plate in situ.
Regards, Tim
Regards, Tim
- Orsom Weels
Jon
oil cap leaks....
a small piece of ali and half an hour...
lotus-twincam-f39/oil-cap-leaking-lot-t31437.html#p210521
oil cap leaks....
Nice. But doesn't it rattle around?
I reviewed the thread and will check the breather pipe for excessive pressure. I've got a carb flow meter which might be able to measure it. I'm pretty sure my breather is leaking too, it used to have Jubilee clips round it (as shown in a photo of the engine way back when the car was blue) but they've since gone.
The dip stick looks OK, I can't see any oil getting pushed past it.
However, I think a lot of the oil comes from the back of the timing chest seal... but the starter motor has oil dripping off it, which "might be the cap if I am really lucky". Which I doubt!
JonB wrote:A couple more questions, if I may...
The plate was for radio noise suppression, used when the plug leads used to go around the back and in under the 'bridge' at the back of the head. It serves no useful purpose if you don't use a radio or your spark leads go over the top.
I?ve removed my engine several times and always do it with the head on, mines a four speed box and I?ve only removed it once which I did once the engine was out. Once the engine is on the hoist and the ancillaries removed and the engine mounts out, dropping the engine a little gives more room to get to the top two bell housing bolts, especially with a Spyder chassis where you can remove the cross member.
My biggest problem was always getting the tubular exhaust manifold in and in the end I changed out the exhaust studs and fitted Allen head cap screws. I know I?ll get comments on the thread failing in the head, but it?s a unc thread and you don?t normally have to undo them more that a handful of times in the life of the car so the threads should be fine. I?ve not had any problems. A good clutch alignment tool is vital if fitting the engine with the gearbox already in the car. With a four speed box, don?t for get to drain and refill the box with oil if you take it out!
- Bigbaldybloke
Users browsing this forum: david.g.chapman, Roland and 28 guests
