Porous Head
Had my engine rebuilt and head ported and polished. It is beautiful, and during the dyno run it performed great except they could not get it to idle. Upon further review, it turned out the head was porous. The engine builder provided another head and finished the engine - which is great. He also sent me the porous head. I assume nothing can be done with it, so if anyone needs a big paperweight it is yours for the postage. I am in Alabama USA.
Bob
Bob
Bob Bulfin
1969 Elan S4 DHC
Mobile, AL USA
1969 Elan S4 DHC
Mobile, AL USA
- bulfin
Depends where and what the problem is. I am assuming it is an old original head. Actual casting porosity is rare so you would need to diagnose more closely what the issue is. Do you have details of the leak location ? If not you can get the head pressure tested to detect where the problem is and then determine if a repair is cost effective.
Some photos of each face of the head would help understand the issue.
I used a twin Cam head that wasn?t salavable for a cut away ?sculpture?. Turned out rather nice
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
It has been repaired as in photos, sorry about order of photos
- alan.barker
Bob,
It may be possible to have the porosity sealed. It's a long time ago when I was working in the chemical industry about 1975. We had a bronze casting made that was porous, and the foundry took it back and sealed it with a resin. I know that's vague, but it might be worth considering.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Thanks so much for all the replies and info. It is a Stromberg head that had been welded several times in the past. My engine builder, a TC expert, ported and polished it and did not realize it had a problem until the dyno runs. He said he should have checked the head more thoroughly, bought me a replacement and ported and polished it, all at no charge. I am pretty sure if this one was salvageable, he would have done so. I may look into it further, but wilkl probably give it to another member who sent me a PM shortly after I posted this.
Bob
Bob
Bob Bulfin
1969 Elan S4 DHC
Mobile, AL USA
1969 Elan S4 DHC
Mobile, AL USA
- bulfin
It looks like the porting thinned the casting on the inlet port bottom section through to the water jacket to much. Any casting becomes porous if it becomes to thin
This is a common problem when you port these heads as the casting core locations tend to vary from head to head.. I had a similar break through when John McCoy was doing a head for me that was picked up at the time and a new head sourced. It was a risk I consciously take when going for his maximum Stage 4 Race porting. Repair welding is possible though often not economic versus buying another head. I had a head repair welded when porting broke through into the valve spring pocket many years ago when heads were harder to source than now, I would probably just get a new head if that happened again.
When working on heads or blocks myself I always keep a very close eye on the wall thickness with an ultrasonic thickness probe if i am taking off metal in areas known to be potentially thin
