Engine fitted
gjz30075 wrote:Interesting motor mount.
I thought the same and the bolts to keep the water plugs in too.
Not seeing an engine earth, do you have a cunning plan for that?
Looks like an extremely well done job so far.
- mbell
Hi Shaun, very nice job. The only thing I noticed is that the design of the engine mounts doesn't allow for much cushioning of engine movement and vibration. I personally would be concerned about the additional stress put on the chassis engine mounts. Like yourself, I have splined U/J drive shafts. Are your's Tony Thompson ones?
- William2
Shaun,
Could you provide more details of the engine mounts you are using.
Your work standard looks excellent, I am jealous.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Brings back memories when I was at that stage of my rebuild (3 years ago). Looks good!
I am also wondering why you installed threaded bolts and washers over the water jacket plugs? I?ve never seen that before.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
The engine mounts don't look fail-safe in the photos ?
If the centre bolt breaks the engine will fall out ?
On standard mounts, fixed the correct way upwards, if the rubber breaks the engine just drops an inch or so.
My engine builder also put in retaining screws/washers for the engine core plugs. Just some added protection for accidental popping out or leaking. I seem to recall reading somewhere that getting proper fitting core plugs can sometimes be a problem.
The engine builder (Dave Vegher) normally builds high revving, high output twinks so may have some experience where these plugs might have been problematic and leaking.
I also note that there are core plug retention plates sold for a number of engines, so other people are concerned about this.
Might be viewed in the same way safety wire is used for added "insurance". Note the safety wire used on the alternator bracket.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Shaun,
Thanks for the reply. I have seen the Kelvedon offering, but did not recognise it on your engine.
Still jealous,
Richard Hawkins
Still jealous,
Richard Hawkins
- RichardHawkins
1owner69Elan wrote:My engine builder also put in retaining screws/washers for the engine core plugs. Just some added protection for accidental popping out or leaking.
In chillier climes core plugs are supposed to act as a 'safety valve' if the antifreeze doesn't do its job.....
Never seen retainers before.
Bizarre!
Roy
'65 S2
'65 S2
elj221c - Fourth Gear
