Page 4 of 5
Re: Elan Sprint-Engine appears to sit very high *Bonnet*
Thu Sep 28, 2017 9:23 pm
by bloodknock
By the time Ive finished assembling and dis assembling this machine, it'll do it on its own.....but then they do the disassembly bit themselves as i remember it - dont they?
Fri Sep 29, 2017 7:43 am
My relieving... ( from below )
Fri Sep 29, 2017 8:19 am
by bloodknock
Hi John,
Looks very similar particularly the depth. Did you do it with engine in situ, if so have your fingers regrown yet?
Did You find that it helped get the down pipes in more easily? Thats my next task, re threading them! It took me ages the first time.
Fri Sep 29, 2017 8:32 am
by bloodknock
Rohan, Alan,
The car came off the road in about 1975/6 Here is a picture of the surface of the down pipes showing surface corrosion that existed prior to cleaning and ceramic coating.
Fri Sep 29, 2017 8:34 am
From memory did it with a burr in the drill ( engine in situ ) and as for the threading in the exhaust...it's a little like the diff...sometimes it's a struggle , sometimes it falls out.
Good luck
Fri Sep 29, 2017 9:28 am
john.p.clegg wrote:My relieving... ( from below )
Exactly the same as the cut out i did on my Sprint Chassis.
When i remove the Engine before putting it back i put the exhaust manifold in the engine bay. Tied to the side with some string.
Before refitting the head always put manifold loose in engine bay.
A friend of mine visited Miles Wilkins years ago and watched him fit a head in an Elan.
After my friend said to Miles i think you have forgotten to put the manifold in place first.
Miles was very mad and the air was blue
Fri Sep 29, 2017 10:39 am
by MarkDa
You'll have to reckon that if you got them off without the extra room on the chassis then going back should be easier!
I thought perceived wisdom was to attach before engine installation, they don't actually a get in the way when doing it.
Fri Sep 29, 2017 8:28 pm
by bloodknock
Done it!
Fri Sep 29, 2017 8:35 pm
by bloodknock
Yes that makes sense, however the block and box went into the chassis even before the shell went back on. However, before I discovered the interferrence snag I had assembled them with the head when i put it on.
To get the space to do the chassis mod I jacked the engine as I removed the NS engine mount completely, jacked the engine to a safe maximum, removed the dynamo and then th manifold.
Its true that the relief makes reassembly easier but its still a bugger, there is certainly sufficient clearance for the manifold now.
Fri Sep 29, 2017 9:59 pm
It's interesting that the header for the 4th appears shaped to give extra clearance for the chassis but it wasn't enough. It looks like if the rear of the engine was slightly higher there might have been more clearance and the problem avoided.
Is that possible or am I just seeing things in the photo's?
Sat Sep 30, 2017 7:26 am
Well done
71 is approaching fast
Sat Sep 30, 2017 8:20 am
by bloodknock
I think that the photo is misleading, the fourth was always clear albeit by about 5mm, it was the No3 which gave trouble.
Mon Oct 02, 2017 3:53 pm
by MarkDa
Going back to the location of the heater valve and why the factory installed it at the rear.
Presumably so the hose could be connected easily to the rear facing outlet.
Swapping round with temp sensor gets everything in the way of each other - valve fouling capillary and bowden against footwell?
Mon Oct 02, 2017 7:12 pm
by bloodknock
Thats the way I saw it.
Mon Oct 02, 2017 11:31 pm
MarkDa wrote:Going back to the location of the heater valve and why the factory installed it at the rear.
That's a bit of "Greek Philosphy" !
In practice swapping the two over is not a problem, except that the heater hose pipes might be too short.
