Elan Sprint-Engine appears to sit very high *Bonnet*
• Page 1 of 5 • 1, 2, 3, 4, 5
"Worried of North wales"
Just installed head on block in the car, relatively smoothe operation but I'm concerned about collision of rocker cover with the bonnet when in place, It appears to sit high and im worried that the rocker cover will hit.
Any comments / advice will be greatly appreciated
Bob
Bob
bloodknock - Fourth Gear
There is not a lot of room, but it should just clear (the cam cover, the rad cap, the top of the front weber...) : best not to slam it the first time around though... in doubt use plasticine to check actual clearance, and adjust engine mounts if need be (after making sure that mounts have not been swapped in the case of the weber head, possible tricks may include filing mounts holes up a bit to lower the engine a few mm, till they collapse from the heat...).
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Or it could be body too low on Chassis.
Have you changed the Chassis because you need to shim the body to Chassis to obtain correct height so Camcover doesn't touch Bonnet.
- alan.barker
Just a quick look but are the motor mounts correctly mounted?
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
71 Spyder Elan, ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 72 Europa JPS #15, 68 Elan Coupe RHD
tvacc - Coveted Fifth Gear
Im pretty sure that the correct mounts are there and on the correct side. However.......
The Chassis has been changed (lotus Galvanised) It all seemed to line up OK. I used the same large washers between the body and chassis in the same places in the rebuild.
OK more investigation required. But I'm worried now weve talked about "Shims". The chassis was pilot drilled from the body during build, but how could I have gauged this issue?
Ive placed a straight edge across the body between the front wings and it just (fractions of a mm) clears the cam covers without the cover gasket in place.
Bob
Bob
Have you fitted the spacers under the gearbox mount ?
S4 DHC
S4 DHC
- oldelanman
Pretty sure theyre there but will double check
Bob
The bonnet has a curve to it and once on, it clears the cam cover by about 5-10mm which is tight but it seems to work ok. I would still check it very carefully when fitting it all back up & closing the bonnet.
Hope that is helpful.
Adam
Adam
- Pastapesto
Adam
Boy I hope thats right, It might just make it, though the cam cover gasket must be about 5mm thick.
thanks again
Bob
thanks again
Bob
There are plenty of cheap small inspection video cameras around, put your mind at rest for a few pounds spent.
- Craven
Craven wrote:There are plenty of cheap small inspection video cameras around, put your mind at rest for a few pounds spent.
For the cam cover clearance (front weber top and radiator cap as well) one can also check it from the radiator opening with a light left near the firewall.
S4SE 36/8198
I had a similar clearance problem on my S4. If you haven't fitted the rad yet you will be able to see the clearance from the front air intake with a torch. On my car I ended up using the same mounts either side (as per Stromberg carbs) and therefore the engine wasn't canted over. Luckily I still had enough room under the air box. Personally I am not a fan of shim washers but I guess in some cases there may not be any alternative solution.
- William2
Bob
I think you'll find the engine's okay for the bonnet as that has a curve to it which you can measure off the car.
I'm sorry to put a dampener on your lovely work on installing the head insitu and by the looks of things you have got the silencers back on now but....The heater valve isn't going to go on without the engine being lifted. You may get it in the temp gauge hole?
Sorry
Sorry
- MarkDa
My heater valve is also in the front (wrong) hole and I am rather pleased that it is because it has gone stiff and I now want to change it. I will not need to move the engine to do it.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Oh bugger! Wheres the Rioja and pass a straw!
Users browsing this forum: Seamus and 8 guests
