Engine Rebuild starts Monday.
I now have the crank installed and the flywheel attached.
All the new QED rings have been gapped and found OK.
So next are the piston / rods etc. I've balanced the weights of the rods to within about 0.5 grams
and the piston + pins are, (1 > 4), 481 482 481 483 grams.
Is it worth balancing the pistons? If so, I assume that metal should be removed from the skirt?
Any other advise or tips?
Vince
Vince
- vincereynard
Thanks Rohan.
Front / back of the skirts - good plan.
I'll take No1 (481 grams) down to where the dial flickers between 480 and 481. Then take the others down to match.
Vince
Vince
- vincereynard
Users browsing this forum: david.g.chapman and 24 guests
