Inlet valve - replace or reuse?
Just stripping a big-valve head ready for skimming and I see that no. 4 inlet valve has some slight pitting (after cleaning off the carbon) on the inside face (ie combustion chamber face, not valve seat). I presume this occurred as a result of the head gasket failure and is related to water entering the combustion chamber. The seat and sealing face of the valve are both fine and show no signs of damage. A compression test prior to stripping was good - the head gasket leak into the cooling system only became apparent when the engine was hot and running at high rpm - so the seat to valve seal was obviously ok. All the other valves are fine too. As I have no spare 1.562" inlet valves in stock, I'm wondering if its ok to reuse it. Normally I would just replace it with a new one but this rebuild has both time and budget constraints. What, if any, are the likely dangers from re-using this valve?
Your opinions are valued and I thank you in advance.
Nigel F.
Nigel F.
- nigelrbfurness
I suppose it will work perfectly well as long as it seals to the seat. I was concerned that the pitting might indicate that the hardened surface of the valve was disintegrating. I'm worried about premature failure - ie the head falling off the stem! Looking at the other valves, the heads were all smooth once the carbon had been cleaned off.
- nigelrbfurness
That's a fair point. A new valve it is, then.
- nigelrbfurness
Be sure to properly grind or recut the seat to match the new valve though! Otherwise there's a strong possibility it will leak and eventually burn due to blowby of hot combustion gas (been there done that). Take a picture of the suspect valve too. Let's have a look
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Nigel
"As I have no spare 1.562" inlet valves in stock", did you mean 1.625?
May have a couple
May have a couple
John, this is what I ordered: http://www.burtonpower.com/inlet-valve- ... fl818.html
I guess they could have got the dimension wrong in the catalogue entry, but I'm assuming that a Sprint inlet valve is a Sprint inlet valve... Wikipedia quote 1.565" for "big valve" twin cams. My workshop manual is in the garage and its raining so can't be bothered to go and look what that says
Seriously, the valves in my allegedly big valve head are slightly bigger than the standard ones but not enormously so by comparison, maybe 15thou? I think 1.625" is bigger still but I'm not an expert.
In replying to the other advice, yes, thanks, I'm aware I will need to lap in the valve to the seat. I've just done all the exhaust valves as they were a bit manky, though the seats are not bad enough to require re-cutting. The inlet valve seats look very good and as the compression was fine beforehand I'm inclined not to redo them apart from the new one. I always put the same valves back in the same position in the head, under some probably mis-guided assumption that the guides and stems will have bedded in together... and the tappet clearances will remain the same!
- nigelrbfurness
Never had a problem re-using all the valves, inlet and exhaust, after replacing head gaskets and giving the head a general clean and face. Valves & guides last replaced nearly 100k miles ago. Three head gasket replacements since then with the head and valves cleaned and checked each time by a trusted machine shop. Last time the valve seats were re-faced as well. Valves, seats & guides were supplied and fitted by QED in 2003.
Unless you are racing, I'd reuse them.
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
Getting a little off topic but...
when I replaced all mine years ago, I was sitting at my work bench and idly tapping one old exhaust valve against another and watching the carbon chip off.
Then one of the heads did as well, 2 tiny little bits of shiny metal were all that was holding it on.........
Ralph.
Ralph.
- reb53
If reusing valves I would always crack test them looking for a crack where the head joins the stem. The can crack their due to being bent during assembly or small misalignment that flex the head every engine cycle.
I have had a used valve head drop into an engine so I am a little paranoid now with used valves. Reconstructing the whole head dome in one cylinder is not cheap
Surely this would apply to new valves? I don't rev the engine much beyond 6.5k, and even then only for very short periods. Racing is different...They can crack there due to being bent during assembly or small misalignment that flex the head every engine cycle.
Jeremy
JJDraper wrote:Surely this would apply to new valves? I don't rev the engine much beyond 6.5k, and even then only for very short periods. Racing is different...They can crack there due to being bent during assembly or small misalignment that flex the head every engine cycle.
Jeremy
Yes misalignment can also happen with a new valve if the guide and seat are not aligned properly or if you have excessive wear in the guide or seat. The flexing of the valve head on the stem to the point that a crack appears is most likely on a used valved in a worn or poorly machined head. Even if everything is concentric and square to the right tolerances and fits in the new assembly, a used valve may have a crack already from its previous life that will lead to a premature failure.
Users browsing this forum: ill_will, MACCA.GLM, promotor and 21 guests
