Light rattle from engine
My engine is together and running finally. It sounds strong but there is a light rattle from the front. We have tried adjusting the timing chain tensioner-chain is new-but the noise is still there. Do the tensioners ever cause problems? I didn't replace any parts of the tensioner since it looked ok.
'65 S2 4844
- Davidb
David, Have a read of this. May not be but worked for me. It is easy to distort the tension quadrant device when replacing the sprocket. mine was twisted. Quite hard to see.
lotus-twincam-f39/clacking-noise-tickover-t30840.html?hilit=lexan cam cover
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Today I stripped out the whole tensioner assembly and checked it-I did not find any problems. It is straight, there is no play in the tensioner sprocket and the 'washer' was on the end of the adjuster. I put it back together and could only run it briefly due to the location and could not test drive but it sounded better! I will run/drive it tomorrow hopefully and will report back.
'65 S2 4844
- Davidb
I had a similar noise and it turned out to the the fan blade rattling in the rivets.
Once I changed to an electric fan and removed the old fan it stopped.
- Concrete-crusher
Steve: I don't have the original fan-I have an electric fan now so that was not the cause of the noise. I ran the car today and got it quite hot - the noise is very minor now-in my humble opinion-I think I will run it for a while and see if it changes.
'65 S2 4844
- Davidb
My fan motor bearing was making a ticking noise until I upgraded but it sounds like yours is new...
A leaky exhaust manifold gasket can make a ticking noise too.
Robbie
Robbie
Run the engine for a VERY short time with the fan belt disconnected and see if that stops the noise. That will isolate alternator, fan and water pump as sources of the noise.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Thanks for all the input everyone. I tried and eliminated all the points that were raised.
Personally I think it is OK. There is a light clatter from the engine which as Bill said is the cam lobes hitting the buckets. There is also a slight chain noise but nothing serious after further adjustment.
'65 S2 4844
- Davidb
Users browsing this forum: LCRJ and 18 guests
