Easy Question to answer: pls help!
this cylinder head is identical to mine. do YOU know the thread size which i'm showing in this picture: it's 1/2" as i measured but i cant measure the pitch etc.... or determine the type of thread (NP, BPPS???) and want to buy two AN8 adapters to get some oil down to the unused gas pump cover (which will also get one of those adapters) - is this a good idea btw?? sandy
- el-saturn
thanks rohan - cyl. 4 is pushing a bit of oil through the collector-gasket, so it leaks downwards and intend to lead it thru the petrol pump cover back into the motor - using dash or AN 8. if someone has a cross-section area I could see whether it may help?? sandy
- el-saturn
