Vacuum pulled by engine
Replacing the vacuum tubes for the lights on a UK version 1967 S3. I have found some nice tygon tubing. It is quite flexible. Does anyone know approximately how much vacuum, the engine will pull at max power? IOW, is hard tubing required?
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto - Third Gear
Thanks Phil. I stand corrected.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
"Max vacuum is actually at idle,"
Think not , Max Vacuum is actually on the over-run , when the engine revs are higher yet the throttle closed ?
john.p.clegg wrote:"Max vacuum is actually at idle,"
You are correct, throttle is closed but engine is rotating faster...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
