correct positioning of the +2 air filter housing pls?
Fri Oct 21, 2016 10:21 am
by RichC
now i have one i don't know how to fit it!
My original one ( or what was left of it ) is long forgotten as it was legged under a bush 8 years ago . All i have left is what i believe was the locating post just to the right of centre on the front lower valance ... Here's a picture taken from standing in front of my old knackered shell looking down into the front valance and i positioned the new air filter housing and the little bracket that came with it next to it but i dont have a clue really how it fits!. The little bracket was a bit bent when i got it but i believe it to be right for the +2 model .
Any help would be greatly appreciated ! The picture shows the front of car to the LEFT .
i've not touched the little bracket as you see it on right hand trumpet ... looks like a little homemade job on LH trumpet. i unbolted the big bracket on the main housing just to be able to clean off the rust and paint it all up.... presume it was gloss black originally? or would it have been satin black? I have both !
I'ts such a lovely day for painting .. it's about 14 degrees & sunny
Re: correct positioning of the +2 air filter housing pls?
Fri Oct 21, 2016 12:01 pm
by bob_rich
Hi Rich
Your rebuild must be close to completion by now..... hope so anyway!
I have attached the pictures of my air filter casing. It had a forward facing strip to the lower body work on the front face then I made a couple of stainless steel strips up one to hold the two inlet pipes together as well as a second one that anchors them to the lower body as well. I have attached the pics
hope they help and it all goes well
regards
Fri Oct 21, 2016 8:37 pm
by RichC
thanks Bob . I would never have guessed the box would be mounted on its side!
is there a reason you pointed your trumpets to the rear?
Given your lead I've played for 5mins with the box in that position but with the trumpets facing forward.
In that configuration the bracket off the box at the back lines up with the vertical rear edge of the front valance .
I'll wait for paint to dry and see if i can put it all in place tomorrow.
RichC
Sat Oct 22, 2016 6:39 am
"is there a reason you pointed your trumpets to the rear?"
any rain/road debris ( small enough to get through the grill ) will end up inside the filter housing.
Sat Oct 22, 2016 8:55 am
by RichC
ah found a picture from an old post .... unsurprisingly the early +2 has a different configuration
the little bracket matches up with my original bracket .
- earlyfilter-2.jpg (50.01 KiB) Viewed 1235 times
Sat Oct 22, 2016 10:40 am
by Elseezed
- Early +2
- Air filter element
Air filter element, had to trim top to fit.
Les
Sat Oct 22, 2016 1:53 pm
by RichC
bit of a bu**er when u want to change airfilter !
Sat Oct 22, 2016 2:23 pm
by bob_rich
Hi Rich and others
I agree that the air filter unit is (according to the cut-away view in the Lotus +2 manual ) normally mounted on its side, with the inlet pipes facing rearwards.
When I obtained my car the air filter was mounted as shown in my earlier pictures and I decided to keep it like that as Rich says it is much easier to change the element when it is mounted vertically.
On my unit there were a number of un-used (by me at any rate) tapped inserts which I guess reflect the original Non lotus applications that it was used on.
hope this helps
Sun Oct 23, 2016 3:16 pm
by TeeJay
In my 1968 +2, the original position was flat.
Following my complete restoration, It is now vertical with the trumpets pointing to the radiator. This helps to prevent the ingress of water and dirt.
The trunking comes out on the right of the car, going to the carburettor air box.
To change the filter, you remove the front nose grill, which allows the wing nut to come off to the left of the car, removing cover with trunking to the right along wth filter, quite an easy procedure.
Also in my +2 workshop manual, it has a page which shows the air filter vertical, this being the later recommended position by Lotus.
Sorry I can't post the manual page or photos, as I am currently away from home, but could post early next week.
Edited to correct how to change the filter.
Mon Oct 24, 2016 8:10 am
by bob_rich
Hi All
Just had a look in my Elan +2 Service Parts List (ref number X050T0325H 1976) and on page 156 diagram E41 it does show the air filter housing vertical with the inlets facing rearwards. so does suggest that it was changed on later models. Mine was a December 1973 +2S and when I got the car
Have attached the picture from the manual which also shows which two brackets and their locations
hope this helps best of luck
Tue Oct 25, 2016 7:06 pm
by TeeJay
Bob has posted info re Parts List, so no need to add to that.
Here are photos showing my air filter fitted in the vertical position.
- View through Nose.
- View with bonnet removed
- View from top of radiator
