poly v pulleys for twin cam
Mon Aug 22, 2016 3:29 pm
by mike in grimston
I occasionally see photo's of elan twinks with poly v belt pulleys for water pump/alternator and crank pulley -yet I cant find any suppliers. does anyone know where to purchase high quality items of this type??
Re: poly v pulleys for twin cam
Mon Aug 22, 2016 7:36 pm
by fatboyoz
Mike,
Can't help you with the poly v belt drive. I have fitted a toothed belt drive (Gilmer drive) kit from Burton Power in the UK. I run the belt quite loose, and the side load on the water pump is minimal. The kit includes three pulleys and the belt.
http://www.burtonpower.com/water-pump-p ... p225k.htmlCheers,
Colin.
mike in grimston wrote:I occasionally see photo's of elan twinks with poly v belt pulleys for water pump/alternator and crank pulley -yet I cant find any suppliers. does anyone know where to purchase high quality items of this type??
Mon Aug 22, 2016 7:52 pm
by Europatc
Welcome Mike, which Grimston are you in?
Mon Aug 22, 2016 10:12 pm
by Mr.Gale
The kit from Burton Power looks interesting but it look like it only connects the crank to the water pump, what about the alternator?
Mr.Gale
Mon Aug 22, 2016 11:22 pm
by fatboyoz
Ah Mr Gale,
Well spotted.
This is the actual item I have: FP225DK. Doesn't actually say it is for the TC, but fits and has been fine for the past 6 years.
http://www.burtonpower.com/water-pump-a ... 225dk.htmlhttp://www.burtonpower.com/parts-by-cat ... s.html?p=5This kit is for an alternator shaft size of 15mm. There is also a kit for 17mm alt' shaft size.
Cheers,
Colin.
Mr.Gale wrote:The kit from Burton Power looks interesting but it look like it only connects the crank to the water pump, what about the alternator?
Mr.Gale
Tue Aug 23, 2016 12:14 am
by SimonH
As shown above the x-flow kit works with a Twin Cam. So going with that is it possible that this poly v kit that also is for an x-flow would work with a Twin Cam?
http://www.burtonpower.com/poly-v-kit-water-pump-alternator-drive-x-flow-711m-fp315k.htmlAs a slight aside has anyone come across this front end drive arrangement before or is it most likely a home brew of parts?
Cheers,
Simon
Tue Aug 23, 2016 9:49 am
by mike in grimston
Although it is not on their website Paul Matty do a kit. 3 pulleys and the belt. Talk to Sam.
Tue Aug 23, 2016 9:57 am
by mike in grimston
Europatc wrote:Welcome Mike, which Grimston are you in?
Not Yorkshire, but Norfolk!
Mon Sep 05, 2016 4:32 pm
by curly type 26
sure I got mine from qed nice kit but as engine not run yet I can only assume should the job do very well curly
