TTR exhaust - TTREX 007
PostPosted: Tue Jul 12, 2016 2:40 am
by europatek
Hi there. Does anyone have some photos of their S4 fitted with this TTR muffler?
I'm interested to see how it looks in the bodywork, know how easily it installed and how it sounds? Does it mount to the original mountings? Is it very loud? Thanks.
Re: TTR exhaust - TTREX 007
PostPosted: Tue Jul 12, 2016 4:54 am
by gav
Im running one with my twink.
Sounds great and I dont think it is too loud. I did a sprint in it last year and it noise checked at 91 db at 6,500 but for roard use I thin it is fine - its only when you really hoof it that it gets loud.
I have the big bore and the engine breathes really well with it.
Just out for the day now. I'll see if I have any photos when I get back
Gavin
PostPosted: Tue Jul 12, 2016 9:35 am
by nmauduit
I have this TTR on my S4 (complete fast road system) : it's not as quiet as the stock system, but bearable on the street (provided you don't rev up too much). It also helps to add lightness : I removed my autoradio...
Installation was easy :
img-20160712-02673.jpg and
rear mount
img-20160712-02676.jpg and
front mount
img-20160712-02672.jpg and
rear mount load spread inside trunk
img-20160712-02678.jpg and
overhang
img-20160712-02677.jpg and
PostPosted: Tue Jul 12, 2016 9:27 pm
by europatek
Thanks guys much appreciated. Do you have a photo looking from the rear - of the whole rear of the car?
I just want to see if the muffler looks "right" in the cutout - not too big, too low, or out of proportion.
I already have a 2" pipe feeding the original muffler and want to get a 2" muffler to finish it off. This TTR item looks like it might be the one.
PostPosted: Wed Jul 13, 2016 10:01 am
by nmauduit
I have found these side and rearish view, will push the car off the storage to take a full rear view later if nobody posts one in the meantime
13433186_1194320970586939_799255048388945036_o.jpg and
Monthl?ry 2016
13411659_1194320860586950_3686562876766226504_o.jpg and
Monthl?ry 2016
PostPosted: Sat Jul 16, 2016 6:12 pm
by Jimnic007
image.jpeg and
Does this work?
PostPosted: Sat Jul 16, 2016 6:57 pm
by Mazzini
nmauduit wrote:I have found these side and rearish view, will push the car off the storage to take a full rear view later if nobody posts one in the meantime
A fine looking car. Love the colour :D
PostPosted: Wed Jul 20, 2016 12:35 pm
by europatek
Thanks guys. My muffler arrived today and I've started to fit it up which seems simple enough except the rear mount which needs to be compact so I can ensure max ground clearance. I need to joggle the main pipe also to line up with the muffler inlet.
PostPosted: Wed Jul 20, 2016 3:04 pm
by nmauduit
europatek wrote:Thanks guys. My muffler arrived today and I've started to fit it up which seems simple enough except the rear mount which needs to be compact so I can ensure max ground clearance. I need to joggle the main pipe also to line up with the muffler inlet.
My lowest point is close to the gearbox (5 speed, so some fettling was done to turn around it), not at the rear.
PostPosted: Sat Jul 23, 2016 11:32 am
by europatek
My muffler arrived early in the week and I set about fitting it up. All but done now apart from joggling the pain pipe to line up. I tried to tuck it up as high as possible as the standard one would ground occasional and this one is larger all over. I managed to reorientate the doubler plates to provide the new mounting locations and cover the old holes - win/win! Now I have a full 2" system ready for my 1700cc stroker engine.
