Lotus Elan
Engine Temp & Thermostat Rating
PostPost by: William2 » Mon Jun 20, 2016 4:24 pm
My rebuilt engine seems to run at about 90 degrees on a warm day whist driving according to the gauge reading. Does that sound ok and am I correct in assuming that the engine would run a little hotter till it is bedded in? Also what is the recommended thermostat temp rating for UK cars? I think mine currently has 82 degrees fitted.
William2
PostPost by: nmauduit » Mon Jun 20, 2016 4:59 pm
I would double check the calibration of the temp gauge with an external thermometer (e.g. for that I use a thermocouple that plugs into a multimeter) : if temperature goes beyond the set point only driving (and not racing, or up a strong hill...) I would make sure timing is not too advanced, carburetion rich enough (plug color) then that the radiator is clean and flows well. My engine runs around 75?C, and barely goes up even when it is 30?C outside.
S4SE 36/8198
PostPost by: richardcox_lotus » Mon Jun 20, 2016 7:51 pm
Mine usually runs about 90 degrees on a warm day.......Sprint with standard small rad.
'72 Sprint
Users browsing this forum: Tony F and 15 guests
