Crankshaft identification
types26/36 wrote:Ron,
Have you any info which Cortina's had a 1500 six bolt crank? the Mk1's had the 1500 four bolt pre Xflow and the Mk2's had a Xflow engine a with six bolt crank although I do believe the first couple of Mk2's were fitted with the MK1 1500 PreXflow engine.
They were as I bought one expecting a X/flow engine only to find a factory fitted pre X/flow 1500 unit it had a GT cylinder head, downdraft weber and 4 branch manifold, not sure if that came from the factory or had been cannibalised from a MK1 Tincorner.
- Chancer
Chancer wrote:types26/36 wrote:Ron,
I have a mk2 1500 cortina that has the original 1500 pre crossflow engine and that has the 6 bolt crank.
The crank is not like a Lotus crank though as it has small counterweights - the Lotus has much larger counterweights.
All of the parts numbers relating to engines are available in the Ford parts books.
promotor - Fourth Gear
