Big bore exhaust.
I have fitted an intermediate muffler ( from an MGB I believe) on my slightly larger than standard diameter Plus 2S 130/5 exhaust system. I have a Spyder chassis and that has a cut out under the gearbox tail which the muffler fits into nicely to avoid reducing the ground clearance significantly. The rear muffler is a single straight through one a little smaller than the original It makes a nice subtle exhaust for the road cruiser that my Plus 2 is and I don't need to avoid using full throttle in the city .
Intermediate silencer now fitted.
The noise is reduced to a more relaxed level. Still a nice sound under acceleration.
Dougal.
Dougal.
- dougal9887
has anyone got any photographs off the clearance problems with a ttr manifold and a type 9 5spd gearbox I can only assume will be similar to lotus 5sd. advice welcome Curly
- curly type 26
Hi Curly.
The following photos show a Steve Jenkins aluminum block fitted with an all aluminum T9 (Quaife aluminum case and cover) tranny, with a Voights conversion kit. The chassis is a bare steel TTR 26R with the largest bore TTR exhaust manifold available and a straight through silencer system (not shown). The pipe pieces are untrimmed at this time.
Bill
Bill
- Attachments
- bill308
many thanks Bill almost same spec as mine apart from standard cast L block didn't want to ceramic coat pipes first and then hit a world of pain so many thanks Curly 1964 26Rr
- curly type 26
