Radiator fan position - S4 RHD
Posted: Fri Oct 10, 2014 10:33 am
I am trying to mount my standard S4 radiator in the correct position from scratch as there are no existing holes drilled in the bodywork for the lower mounting brackets. I have both the side pre-drilled brackets in position. The body is currently removed from the chassis. I would be very grateful if someone could take a few measurements from their car to give me some datum points for the vertical position and for and aft. I guess the two important issues are that it is clear of the steering rack U/J and that the filler clap is clear of the bonnet. A suggested measurement would be from the vertical face of the master cylinder bulkhead to the edge of the radiator itself if this is possible. Also is the rad immediately above the U/J when in the correct position? I am assuming that if the rad is slightly closer to the engine that is not a problem.
