Rear cylinders not firing/misfiring
Now. Ease off on turning the. Balance. Screws you may want the screw just to be free of touching the front carb tang the rear carb needs actuate a shade before the front ....try that ....sounds like you are screwing it in too far oiiii....that should get me banned again
I use a Colortune transparent spark plug to set the idle mixture. You can't beat being actually able to SEE the colour of the flame.
And you can be absolutely sure that it is firing.
Defininitely worth the money and lasts for ever.
Hi Timok, did you resolve the issue with the two rear cylinders (3&4) as I have the identical problem, equal good compression on all cylinders, good spark on all plugs, electronic ignition just installed, both floats set the same height, fuel present at same level in both carbs when floats removed, carbs just serviced, correct firing order, etc
I can take both rear plug leads off and it makes no difference, the engine starts and runs lumpy obviously as on two front cylinders but run it does !, I’ve tried easy start on both rear chokes but no difference, the only thing I haven’t done is swop the carbs front to back which’s my next step, any suggestions most welcome
- Fuzzy748
Hi, yes firing order/plug caps correct, I haven’t had it running previously as I bought it as a complete car that had been stored for some time, what I don’t understand is just how well it runs without 3&4 plug caps connected, I thought it wouldn’t run at all,
- Fuzzy748
Check out carb synchronization, if you don’t have any equipment for this, with air box removed a suitable length of hose pipe the larger dia the better and listen for equal hiss at each trumpet.
Balance between carbs is adjusted by spring loaded screw between carb on spindle. On pic above throttle cable.
- Attachments
- SPRING ON CABLE.JPG (66.71 KiB) Viewed 1753 times
- Craven
I'm no mechanic, and I have little to no experience with carburetted engines. Any help is greatly appreciated!
-Timo
Imho Timo you would be better to contact a classic car garage and get them to set it up
Quicker and easier as you said you're no mechanic.
-Timo
- alan.barker
If you got hold of a gunsons color tune you could see the 2 cylinders firing, and set the idle mixture.
Just a suggestion
Just a suggestion
- Concrete-crusher
