Stripped Sump Plug
Merci, Gary. No need for the photo though - I think everyone would have trusted your memory.
What's the grass in the picture, though - I thought you did everything indoors
Vernon
Vernon
vernon.taylor - Fourth Gear
vernon.taylor wrote:Merci, Gary. No need for the photo though - I think everyone would have trusted your memory.
Vernon
I didn't know, I had to pull a pan out of the stack of assorted sumps and find the wrench, it was out in the shed. The photo is on the front entry porch. I also looked in the parts manual to see if it was listed with a thread size (it wasn't). While I had the thought in my mind, I pilled out the sump plug out of the rope seal pan that I stripped off the engine last week and looked for a nut to fit, I only had up to 5/8 unf and it was to small so I just eyeballed it with the tape measure and it looked to be 3/4 but was to fine of a pitch to be a unf thread. So if anyone else knows what it is that would put more info all in one topic.
Back in 1981 I bought a 1969 Ford Fairlane with a 302 V8, it had a rubber sump plug, It was inserted into the stripped out sump hole. I went to change the oil and tried to extract the plug, seems that a special tool was needed to stretch the plug and then it was withdrawn. I didn't know so I ripped it out with brute force. It kind of looked like this one except it was a bit longer .
It seems from this New Zealand catalogue that (i) the hex size of a sump plug is no guide to the thread diameter and (ii) this firm supplies "oversize" plugs, e.g. the oversize 1/2" 20 tpi plug is 20 tpi but 0.515" diam.
Might be useful if you lived in New Zealand.
http://www.acl.co.nz/Ecat/images/Drain%20Plug%20Catalogue.pdf
Robert
- rcraven
hi im new on here,i was just having a read ive done a lot with x/flow engines and sumps over the years and i come up with a real good fix for knackard sump threads,the sump needs to be off the engine,I made a slim boss that welds on the sump i will post a picture if i can work out how to post up pictures on here,then you can use the later sump bolt with a better thread,
- rick deregus
