Lotus Elan
Alternative radiators again
PostPost by: vernon.taylor » Sun May 27, 2012 7:39 am
Salut Steve
I think you misunderstood Jason. His link is to the Vendors and For Sale pages of our forum. You just need to click on 'New Topic', and enter your subject (e.g. 50% radiator discount ;-). This will appear in our forum only - nothing to do with Google.
Hope to see your entry soon.
Vernon
vernon.taylor
PostPost by: TonyJ » Sun May 27, 2012 4:04 pm
Vernon
Yes bought aluminium radiator, painted black with one fan. As I said you wouldn't think it wasn't a standard fixture as it blends in, I even think the cap is in the same place as original.
Took her out Saturday and today, Sunday, and despite the hot weather I didn't have to worry. Temp guage went up to the mark after 80 a couple of times, when in traffic, but the fan coooled it back to 80. The ambient temp guage read 40 after our pub lunch and only fell to 30 when moving! With the old radiator I would have had the heater blasting out hot air into the cabin in an attempt to keep the gauge from rising and rising, most unpleasant.
Thanks coolexperts, I'll definitely write a testimonial if needed.
Here's to many more fun driving weekends 8)
Regards, Tony
DSC00549.JPG and
DSC00551.JPG and
DSC00550.JPG and
TonyJ
PostPost by: coolexperts » Mon May 28, 2012 8:09 am
Thanks for that tip Vernon I will do that soon.
coolexperts
PostPost by: coolexperts » Mon May 28, 2012 8:28 am
Thanks TonyJ,
Last weekends U.K. weather would definitely test your new radiators capability, glad it came through with flying colours.
I am off to start a new thread on radiator fit and fan temperature switches. If you get time I would value your comments.
Steve.
coolexperts
PostPost by: coolexperts » Wed Jun 27, 2012 5:39 pm
Hi Vernon,
Keeping you informed as promised. We are In the advanced testing stage of a full width aluminium radiator with plastic top tank, bottom tank, and fixing brackets for the Elan. This radiator will be sold with options to buy from us a Lotus Cortina 90 degree thermostat housing with filler cap, a 90 degree top hose, a bottom hose, and a 10" inch fan. This will be a bolt on job with no serious modification required. I am attempting to get the whole package out for ?195.00 including UK VAT. This would be plus postage to France. Is this of interest to you? Could you let me know what radiator you have at the moment and what series your car is. Regards, Steve.
coolexperts
PostPost by: vernon.taylor » Thu Jun 28, 2012 9:45 am
Hello Steve
Thanks for getting back. A photo would be useful - if you send it to my email address I'll post it on the forum if you're not sure how to.
A couple of questions:
1. Sounds like the thermostat housing is the Burton Power offering?
2. ?195 for the WHOLE package - radiator + brackets + thermostat housing + hoses + fan ?!!
3. Are two 10" suck fans possible (between radiator and engine)?
I have a 1971 Elan Plus 2S/130. Current radiator is a reconditioned 3-row Stanpart narrow radiator and 10" blow Kenlow fan.
Best regards
Vernon
vernon.taylor
PostPost by: coolexperts » Fri Jun 29, 2012 2:12 pm
ecoelan1.png and
I could only get a low quality photo on but I think it will show you the radiator OK. The thermostat housing is available from Burton power and is also still available from Ford. It used to be fitted to the XR2i amongst other models of that period. I am happy to supply radiator only. I will offer the radiator with or without various options so that if you wish to source your own fitting kit, hoses thermostat housing, fan, etc, you can do so. Hope to be test the unit this week and be available for sale in 2 to 3 weeks.
coolexperts
PostPost by: coolexperts » Fri Jun 29, 2012 4:09 pm
Forgot to answer the fan comment. I have to fit this to a car to guarantee being able to say that the fans will fit the engine side of radiator. They will definitely fit the front side which is always best in my opinion because the motor is not running in a stream of hot air.
Steve.
coolexperts
PostPost by: jono » Fri Jun 29, 2012 6:30 pm
I have manged to fit 2 x 10" Spal slim line pullers on my Cliveboy rad. They just fit but it's tight - you have to mod you bracket position and I will still need to crush the trunking a little to get the bonnet to open and close.
However having them engine side does overcome much of the problem of getting your trunking past the front fan at the bonnet brace pinch point (with a 2 fan setup).
What convinced me to go with pullers is that you have the full face of the rad presented to pull the incoming cold air across, so a bigger transfer area. Also, with the very dense Cliveboy core it seemed logical that air would pull through better than it would push through - physicists will probably tell me that is wrong but it seemed instinctively right to me somehow.
I think I may be right in saying that most (all?) modern cars use a puller system - no point in pulling warm air from the engine bay over the rad I guess is one reason?
I used a Burton top stat housing with a Revotec adjustable switch and a custom silicone top hose.
The Clivey rad has not filler cap and it clears the bonnet with plenty to spare. It looks in period too and would, I feel sure, cope with Death Valley.
Overkill perhaps but I plan to use my car for continental trips and I don't want to leave anything to chance. Also, it's a small price to pay for looking after that expensively re built TC motor.
Will post up some pics shortly.
Jon
PostPost by: jono » Tue Jul 03, 2012 8:16 am
I have attached the photos as promised showing my twin puller fan arrangement using the Clivey rad
Jon
4.JPG and
3.JPG and
2.JPG and
1.JPG and
PostPost by: coolexperts » Fri Jan 11, 2013 8:56 am
For an update on our position please checkout our business and vendor insertion:
business-listings-f3/www-coolexperts-cooling-systems-t25946.html
regards Steve.
coolexperts
PostPost by: vernon.taylor » Fri Jan 11, 2013 7:15 pm
Salut Jon
Is that an eBay washer bottle you're using for the overflow bottle?
Vernon
vernon.taylor
PostPost by: jono » Fri Jan 11, 2013 9:12 pm
Hi Vernon,
Yes it is. I bored out the top and used 8mm copper tube, slash cut at the bottom, bent and made it a tight fit into the top with a grommet. Seems to do the trick and looks reasonably 'period'
Jon
PostPost by: coolexperts » Wed Sep 11, 2013 7:42 pm
In the light of various members fitting VW / Audi Etc Etc radiators to their Elans, we have developed
a new crossflow aluminium radiator that bolts straight on to the car with little or no modification. The
radiator has plastic tanks and comes with a 10" slimline fan fitted on proper brackets and mounted
against the radiator to ensure that the air is forced through the core. Also included is an aluminium
pipe with filler neck, mounted above the radiator to ensure no air locks.The aluminium pipe is also
fitted with a Lucas type fan operating switch working at on 82 degrees and off 68 degrees. Your
existing hoses are trimmed to accept the new radiator and filler tube. The complete package as
shown is sold to forum member for ?215.00 plus shipping of ?10 in the U.K. If you are interested
please email: [email protected] or phone and chat on 0115 942 3344 and ask for Steve.
Please see our other products in the Sponsors and Business / Vendors section.
coolexperts
PostPost by: Pistacchio sprint 72 » Wed Sep 11, 2013 8:08 pm
Well whatever rad you choose, i strongly advice you to forget the burton housing which is oriented for a xflow and not a twink.
(Unless you go for the 26r style with the additionnal filler box)
Get instead the correct thermostat housing, the hose routing is much cleaner and natural with no bend.
And now i can stamp it " rally proven"!
image.jpg and
image.jpg and
Last edited by Pistacchio sprint 72 on Tue Sep 17, 2013 6:03 pm, edited 1 time in total.
Cooled down by CliveyBoy!
PreviousNext
