Lotus Elan
PostPost by: SJ Lambert » Mon Jan 06, 2014 9:42 am
image.jpg and
That pesky sprocket dowel hole on the inlet cam hasn't benefited from a visit to Melbourne.
Next stop - home made flapper or maybe back to Melbourne?
Elfin Monocoque (Twin Cam)
[email protected]
SJ Lambert
PostPost by: rgh0 » Mon Jan 06, 2014 9:54 am
Have you talked to Clive at Clive Cams on how he puts holes in twin cam blanks?
PostPost by: SJ Lambert » Sun Jul 13, 2014 7:18 am
Spoke to Clive, he told me the same thing Dad & John had - stop pissing about with enlarging the cam hole, slim down the dowels.....
Don't even need a lathe.....
image.jpg and
Turns out I shoulda been using my ears!
Have altered a pair of no off set dowels to suit for trial build, can then do the same as necessary to off set dowels to time them in for final build.
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Sun Jul 13, 2014 8:56 am
image.jpg and
Got round to affixing second engine plate
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Mon Jul 14, 2014 12:57 pm
image.jpg and
Once compression ratio has been sorted, it won't be far away from going together.
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Tue Jul 15, 2014 9:27 pm
image.jpg and
The motor's original clutch
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Wed Jul 16, 2014 10:27 am
It's manufacture date is Feb 1964. I wonder what model Porsche it's sourced from?
[email protected]
SJ Lambert
PostPost by: rgh0 » Wed Jul 16, 2014 10:44 am
Hi James
Can I see some more photos of your cylinder head #LP5332 from all sides. From the couple you posted in this thread it looks like an early type 2 head (i.e. no square boxes on forward two inlet tract bases) and at that engine number would make it the earliest known as current earliest type 2 head is LP6075. What date was your engine built?
PostPost by: SJ Lambert » Wed Jul 16, 2014 11:25 am
Sure, just missed an opportunity to photograph it in Tassie last week - am back on the big island now, shall hunt through existing shots when I get a chance.
From memory the engine (block) is stamped by Cosworth as a January 66 assembled engine and it's Laystall crank is stamped November 65. I don't recall exactly why, but I have a notion that it's a motor assembled at St. James Mill Road not long after they moved out there.
So I guess that the head must have been produced 3 to 6 months or so (no real idea of lead time) earlier than that in order to be finished to Mk 16 spec in early 66.
James
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Wed Jul 16, 2014 11:28 am
image.jpg and
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Wed Jul 16, 2014 11:33 am
image.jpg and
[email protected]
SJ Lambert
PostPost by: rgh0 » Wed Jul 16, 2014 11:47 am
It appears to have some extra oil drain holes plugged on the exhaust side is that correct?
Do you have a photo of the rear face and bottom face to show the numbers there?
Certainly appears to be the earliest type 2 head produced by date and engine number. it would make sense that this ended up in a race engine as these heads are clearly superior to the type 1 heads in breathing potential with larger inlet tracts.
PostPost by: SJ Lambert » Wed Jul 16, 2014 1:30 pm
Yes, plugs are glued in with Araldite by the looks (and other parts, like front oil breather hole in cam cover blanked off with aluminium insert that is definitely araldited in).
Haven't found rear face & bottom face shots yet, inlet tracts look pretty good, though haven't compared them with standard later heads, there's not been much done to combustion chambers, but we'll keep it exactly as is.
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Wed Jul 16, 2014 1:48 pm
Sleeves for buckets in exhaust side only.
[email protected]
SJ Lambert
PostPost by: rgh0 » Wed Jul 16, 2014 1:57 pm
Hi James
Thanks for the photos and comments on the follower sleeves. I know Lotus went through - no sleeves, sleeves in exhaust, sleeves in both inlet and exhaust variations, but all this occurred early on according to the Wilkins book and I expected all Type 2 heads to have sleeves in both but it appears not!!!
Its only the absence of sleeving that's meaningful - an early head with sleeves can always have had them added at a later rebuild date.
PreviousNext
