Engine Installation-easy options?
PostPost by: nico506 » Sun Nov 06, 2005 1:01 pm
Hi all,
I am now in the process of installing the restred engine back into my Elan S3 following body respray and installation of ancillaries.
I would like some comments from others as to the process of installing the engine without scratching the paint- and whether it is easier to install the short engine first and the the gearbox - or install the long engine incuding the gearbox whichever reduces the need to curse badly :shock:
I have considered removing the body to do this - but nervous of damaging the paint or stressing the body in the process as it is difficult to grab the body without using the arches as I did prior to the restoration(incorrect I know).
Any help or advise would appreciated- I live in Bedfordshire UK so if anyone willing to assist that would be great.
Thanks in Advance
nico506
PostPost by: type26owner » Sun Nov 06, 2005 3:38 pm
Definitely install the engine separate from the gearbox. I've done it that way at least a dozen times now. You can remove the engine and put it back in the car in one 8 hour day by yourself once you know all the tricks and procedures.
type26owner
PostPost by: rgh0 » Mon Nov 07, 2005 9:00 am
I agree with Keith and always remove and install the gearbox and engine separately. I did it once the other way many years ago and never will again.
PostPost by: types26/36 » Mon Nov 07, 2005 9:16 am
I've done it both ways and I prefer to remove the engine separately but refit the engine and gearbox together as a unit.
Brian.
types26/36
Users browsing this forum: TonyWylde and 17 guests
