Using an Oscilloscope for engine diagnostics.
While going through some of my old electronics magazines from the 1970's I came across this very useful article.
- Attachments
- ETI_Feb77_ScopeTheIgnition_1b.pdf
- Using an Oscilloscope to diagnose engine problems
- (881.55 KiB) Downloaded 13677 times
So we'll all go and dust off our old oscilloscopes!!
'67 S3 SE FHC
'67 S3 SE FHC
You're far ahead of me, Mr. W!
'67 S3 SE FHC
'67 S3 SE FHC
IIRC Snap-On Tools makes a hand-held auto diagnostics scope, about the size of a dwell/tach or VOM, that would be pretty handy. Probably a bit spendy though.
Jim
Temporarily Elan-less
summerinmaine - Fourth Gear
billwill wrote:Once upon a time, long ago, I bought a little 2 inch CRT with a vague plan to build an oscilloscope into my dashboard.
Your idea has me intrigued, so I looked around a bit. You can get a DIY kit to make a DSO for short money, as reported on this link. Prices may have changed a bit, and it would take some fiddling to set it up for automotive applications, but it would be an interesting project. Rather than build it into the dash, I'd enclose it and set it up for a GPS mount. Wonder if the vibration for road travel would hurt it?
Or, forget the CRT and get one that uses a TFT LCD panel!
Jim
Looks like a nice piece of kit at that low price. I might order one.
Makes it all a bit too easy though
My CRT is about 8" long, so I would have needed a glove box full of electronics.
My existing 'scope is about as old as my Elan and is a rack mounted valved thing and the sync doesn't work well
<later>
The sample length on that first scope you found is only 256 samples which are probably not enough for ignition diagnosis, so this one is probably more suitable at 4096 samples and $89
http://www.seeedstudio.com/depot/dso-na ... th=104_108
<later>
the best automotive scope at the moment is the pico scope, the two channel jobbie would do the job for setting up carbs and diagnosing ignition problems. Its PC(laptop/netbook) based and is around a grand. look for 2nd hand on fleabay, where some one has upgraded to a 4 channel.
http://www.picoauto.com/automotive-oscilloscope.html
contact me if interested
i have compared it against the Snap On Vantage Pro and Modis scopes and they dont come close,
another good portable scope is the Bosch PMS100 by fluke and its derivatives, these are stand alone (no need for a PC) but a bit pricey I've got access to some new old stock kits at around ?1600+vat if any one is interested
regards
regards
- tower of strength
tower of strength wrote:the best automotive scope at the moment is the pico scope, the two channel jobbie would do the job for setting up carbs and diagnosing ignition problems. Its PC(laptop/netbook) based and is around a grand. look for 2nd hand on fleabay, where some one has upgraded to a 4 channel.
regards
Those all sound great, but I'm just a poor barrister, so I'm looking for a DIY penny (pence)-tech solution.
But I do like the idea of using a laptop PC, instead of having a special purpose (redundant) screen.
Jim
Jim
