Radiator recovery bottle position
Mine's to the right of Roger's, on the other side of the air ducting in the bottom pic. The bracket is fastened to the side wall at floor level just in front of the rad. To the best of my knowledge that's where it's always been.
Stuart
Stuart
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
My bracket does have holes for both bottom and side fixing but has always been mounted where shown in the pics. The base of the bracket is angled so the bottle is upright when mounted on the sloping body so it looks right. There is not room in my engine bay to fit it where Stuarts is as the air ducting runs too close to the inner wing - I suspect that the air cleaner positioning was a bit variable as well ! Any other variations out there ?
S4 DHC
S4 DHC
- oldelanman
The location on my Sprint is as per Rogers'. Although it's not as impossibly clean as his....
'72 Sprint
'72 Sprint
- richardcox_lotus
For the S4 I believe Roger's bottle is correctly positioned. Here is a link to a road test of a Sprint, from 1971, at the bottom of which is a good shot of the engine bay and bottle:
http://www.lotuselansprint.com/Document ... tMar71.pdf
That test car was one of the factory S4/Sprint versions, so based on the 1970 S4
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
I am not going to comment on originality...
However, if you want the airflow form driving to cool the water in the radiator, move the clutter in front of the radiator of the flow of air.
The space on the radiator mounting bracket for example, is not used and can mount the overflow bottle.
Jason Farmer
Jason Farmer
- memnon
Fantastic responses as always! which brings me on to whether I need to change the radiator cap. I know there's other threads relating to this but I thought some fresh thoughts on this might be useful! My cap is fairly basic (i.e. just a single spring mechanism). Do I need to change this for the recovery to operate effectively? (My local supplier is Paul Matty).
- 106500
richboyd9 wrote:I thought the Tudor bottles have been superseded by the Windsor bottles.
The Tudor bottle was superseded by the Stuart bottle.
Unibrain - Third Gear
106500 wrote: My cap is fairly basic (i.e. just a single spring mechanism). Do I need to change this for the recovery to operate effectively? (My local supplier is Paul Matty).
I've collected a few rad caps over the years trying to get the cooling system to work and I'd never realised that there was a two way valve mechanism in the correct one until I read about it here earlier in the year. The car had only ever dumped water into the recovery bottle previously, never sucked it back again.
I replaced the cap with a two way one (one of the junk ones turned out to be the correct one once I knew what I was looking for) and the car's not used a drop of water this year - about 3000 miles. It still amazes me - it's never done this before in over 25yrs of ownership.
Easy to get a bit confused with the Windsor bottles, they're just rebranded German ones. I did come across a report recently that an Australian company had got the manufacturing rights to the really old Plantagenet bottles but unless you're looking for ex factory originality it's probably better to stick with the more modern stuff.
Stuart Holding
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
My S4 has the bottle in the same position as Roger's.
Keith Marshall
- saildrive2001
Users browsing this forum: 69S4, elanman999, mark030358 and 17 guests
