Page 2 of 2
Re: nut torque specs, especially cam cover bolts
Thu Aug 15, 2019 9:06 am
by 69S4
If you mean the cups for the O rings I think he made them himself, so not a commercial product:
prezoom wrote: I then machined up some cups out of 1/2" aluminum rod, which were bored deep enough to contain the "O" ring, but leave about 1/4 to 1/3" of the ring proud of the cup. I used a 3/8" end mill to counter bore the aluminum rod to the correct depth.
Rob
26-4889
Thu Aug 15, 2019 3:20 pm
by prezoom
Yes, I made them up as the ones that were on the engine when I purchased the car were beyond their sealing life. They have been on the engine since 2006, and are still doing the job, no leaks whatsoever.
Thu Aug 15, 2019 4:41 pm
by joe7
Why not just use a "Stat-O-Seal Sealing Washer" with a flat washer on top. Pegasus in the US has these in various sizes. I use one on my oil pan drain bolt without a washer and never had a leak. That is torqued to 28 ft/lb and they are reusable.
Fri Aug 16, 2019 2:53 am
by prezoom
Because I had some short pieces of aluminum round stock, and Real Seal, a large "O" ring supplier is just a couple of miles from my house and stock just about every sort of O ring in any sort of material and are willing to sell in any quantity. I made up a set for Gary when the subject came up, and sent them to him for him to try. Unfortunately, he had had enough and bailed from this forum. Major loss for this forum.
Fri Aug 16, 2019 6:03 am
by 2cams70
joe7 wrote:Why not just use a "Stat-O-Seal Sealing Washer" with a flat washer on top. Pegasus in the US has these in various sizes. I use one on my oil pan drain bolt without a washer and never had a leak. That is torqued to 28 ft/lb and they are reusable.
As well as Stat-O-Seals these are good too. They also can seal around stud threads preventing leakage between threads.
https://www.digikey.com/products/en?mpart=75801&v=335
Fri Aug 16, 2019 6:25 am
by herrherr
Thanks for the other recommendations. Looks like I missed Robs post where he explains how he made them
I had some major problems figuring out how these things are called in German. Just in case someone is ever wondering about the same, they are called a "Usit-Ring".
Fri Aug 16, 2019 2:23 pm
by SENC
These Bartite sealing washers were recommended to me, to be installed and tested in the coming weeks.
Sat Aug 17, 2019 1:59 am
by 2cams70
They look good!
Sat Aug 17, 2019 12:42 pm
by snowyelan
These ones seal on the thread as well.
https://www.mcmaster.com/93781a029
