Lotus Elan
nut torque specs, especially cam cover bolts
PostPost by: 69S4 » Thu Aug 15, 2019 9:06 am
If you mean the cups for the O rings I think he made them himself, so not a commercial product:
prezoom wrote: I then machined up some cups out of 1/2" aluminum rod, which were bored deep enough to contain the "O" ring, but leave about 1/4 to 1/3" of the ring proud of the cup. I used a 3/8" end mill to counter bore the aluminum rod to the correct depth.
Rob
26-4889
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: prezoom » Thu Aug 15, 2019 3:20 pm
Yes, I made them up as the ones that were on the engine when I purchased the car were beyond their sealing life. They have been on the engine since 2006, and are still doing the job, no leaks whatsoever.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: joe7 » Thu Aug 15, 2019 4:41 pm
Why not just use a "Stat-O-Seal Sealing Washer" with a flat washer on top. Pegasus in the US has these in various sizes. I use one on my oil pan drain bolt without a washer and never had a leak. That is torqued to 28 ft/lb and they are reusable.
joe7
PostPost by: prezoom » Fri Aug 16, 2019 2:53 am
Because I had some short pieces of aluminum round stock, and Real Seal, a large "O" ring supplier is just a couple of miles from my house and stock just about every sort of O ring in any sort of material and are willing to sell in any quantity. I made up a set for Gary when the subject came up, and sent them to him for him to try. Unfortunately, he had had enough and bailed from this forum. Major loss for this forum.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
prezoom
PostPost by: 2cams70 » Fri Aug 16, 2019 6:03 am
joe7 wrote:Why not just use a "Stat-O-Seal Sealing Washer" with a flat washer on top. Pegasus in the US has these in various sizes. I use one on my oil pan drain bolt without a washer and never had a leak. That is torqued to 28 ft/lb and they are reusable.
As well as Stat-O-Seals these are good too. They also can seal around stud threads preventing leakage between threads.
https://www.digikey.com/products/en?mpart=75801&v=335
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2015 Honda City 5spd.
PostPost by: herrherr » Fri Aug 16, 2019 6:25 am
Thanks for the other recommendations. Looks like I missed Robs post where he explains how he made them :)
I had some major problems figuring out how these things are called in German. Just in case someone is ever wondering about the same, they are called a "Usit-Ring".
herrherr
New-tral
PostPost by: SENC » Fri Aug 16, 2019 2:23 pm
These Bartite sealing washers were recommended to me, to be installed and tested in the coming weeks.
img_20190816_102055.jpg and
Henry
69 Elan S4
65 Seven S2
PostPost by: 2cams70 » Sat Aug 17, 2019 1:59 am
They look good!
PostPost by: snowyelan » Sat Aug 17, 2019 12:42 pm
These ones seal on the thread as well.
https://www.mcmaster.com/93781a029
Scott
45/9011
Hawkestone, On, Ca
snowyelan
Previous
