Lotus Elan
Running Problem
PostPost by: Matt7c » Wed May 18, 2005 7:47 pm
Back to the original question, are you sure the snag is heat related. I recently had a similar problem, but it was caused by a restriction in the fuel pick-up pipe in the fuel tank. This meant that after a few minutes of running (coincidentally when it was hot, though this wasn't a factor) the fuel bowl in the carbs ran dry. Naturally, this symptom is easy to check for by looking at the fuel level in the carbs when it has stopped (assuming your floats are correctly set).
1965 Elan S2
Matt7c
PostPost by: Hamish Coutts » Wed May 18, 2005 9:18 pm
Absolutely agree with Matt7c.
I chased a fuel problem for ages eventually to find that there was a piece of rag stuck in the fuel pipe that was partially blocking the fuel supply. If the engine was ticking over there was enough fuel flow to fill the float chambers. With a bit of throttle the float chambers gradually emptied and then stuttering and coughing and eventually a dead engine. Very frustrating!
I have an electric fuel pump.
Hamish.
Hamish Coutts
PostPost by: cliveyboy » Thu May 19, 2005 7:29 am
The later Sprints did use a ballasted system as mine has one.
I have also been using electronic ignition with it and had no problems.
Clive
1972 Elan Sprint FHC
cliveyboy
PostPost by: M100 » Thu May 19, 2005 8:08 am
Leave the fuel filler cap off and see if that helps
Regardless of ballast coil or not i'd get ANY known good non ballast coil, wire it direct to the battery not through any immobiliser/ignition switch etc, provide a dedicated earth from the engine block to the battery (jump lead) and also use a points actuated ignition with a known good condensor
If it dies then
a) check the fuel pump bowl (if glass) for fuel
b) remove the float chamber cover and check for fuel
c) check spark plug insulators to see if there is any radical temperature spread
d) remove spark plugs and check for fouling
Martin
72 Sprint DHC
M100
PostPost by: wobblyweb » Thu May 19, 2005 11:20 am
Thanks for all the suggestions.
It is looking like a sticky exhaust valve.
I will post when that is fixed and see if it is cured.
wobblyweb
Previous
Users browsing this forum: mbell, pdenton26 and 16 guests
