Lotus Elan
water pump
PostPost by: steveww » Fri Jun 22, 2007 11:29 am
I remember reading some where that water pump failure can be attributed to lack of use. Something to do with the bearing sitting stationary surrounded by coolant? I am sure an over tight fan belt does not help either.
If I ever have to do the one on my S4 again, I will fit one of the Burton cartridge type.
steveww
PostPost by: AlfaLofa » Fri Aug 26, 2011 10:23 am
If I fit a Burton water pump and Burton timing cover can I still use the original Lotus back plate?
If a replacement back plate has to be used, I think I will stick to a standard replacement pump.
I've hunted for the answer. It's probably here somewhere but I can't find it.
'64 S1 Elan (Owned since '73)
'69 Alfa Romeo 1750 Spider Veloce (Owned since '77)
'70 Morris Minor 1000 (Owned since '85)
AlfaLofa
PostPost by: bcmc33 » Fri Aug 26, 2011 3:00 pm
AlfaLofa wrote:If I fit a Burton water pump and Burton timing cover can I still use the original Lotus back plate?
NO.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: pereirac » Fri Aug 26, 2011 4:04 pm
I am running a standard setup with a dynamo. The only time I had problems (water leaking) was when I tried to do the pump myself (young and innocent then). Peter Day replaced my pump in the late 1980s and it's still going strong after about 45k miles.... I have a very loose fan belt but everything works (although not at the same time... the indicators and wipers slow down if I have the heater fan, headlights and wipers all on at the same time - usual British weather).
I remember that there were some horror stories going around then regarding the quality of some of the third party capsule replacements (I still have a copy of a letter sent to Club Lotus by a disgruntled member)
I suppose I am asking for trouble now :)
Carl
72 Elan Sprint
87 Excel SE
97 Alpina B10
http://www.lotuselan.co.uk
pereirac
PostPost by: martinbrowning » Fri Aug 26, 2011 4:43 pm
I have always used the standard Lotus water pump in all my Loti over the past 30 years - no problems provided that you use genuine parts and do not over tighten the fan belt. In my latest rebuild I bought a new front timing cover from QED, to avoid the usual corrosion problem.
Just my sixpence worth...
Martin B
martinbrowning
PostPost by: pereirac » Tue Aug 30, 2011 11:47 am
... Just notice my car has a small water leak.. hope it's not the water pump but a hose.. :cry:
Carl
72 Elan Sprint
87 Excel SE
97 Alpina B10
pereirac
PostPost by: SJ Lambert » Tue Jan 23, 2018 6:32 am
I?ve lost the original Belt off my Twin Cam Race motor that was just a crank pulley to pump pulley one - from memory it was a Dunlop A21 - does anyone know where I can source a correct replacement?
Elfin Monocoque (Twin Cam)
[email protected]
SJ Lambert
PostPost by: rgh0 » Tue Jan 23, 2018 10:43 am
Same as a twin cam Europa if you have standard pulleys ?
PostPost by: rgh0 » Tue Jan 23, 2018 10:46 am
standard belt specs are typically like... 11 A 210
11mm width
A profile
210 length
various manufacturers incorporate these number into their part numbers or have the full specification on the belt
PostPost by: Hawksfield » Tue Jan 23, 2018 9:51 pm
Two water pumps in 33 years and the first was replaced as matter of course when I had the head done by QED
The cartridge sounds nice but expensive for a standard road engine. A good option if your front covers need replacement otherwise standard for me.
+2s130 1971
PostPost by: SJ Lambert » Thu Jan 25, 2018 9:05 am
Made some progress today - we found the old belt which is 580 outside length & is a 9.5/6.44 wedge. A Z21 is a bit tight, so a cogged xpz 562 with outside length 575 wedge 10/8 may do the job - QED offer a spz562 for the Europa. If all else fails Inmay spread the pump pulley a bit to let a Z21 lower into it.
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Fri Jan 26, 2018 10:30 pm
I?ve also just realised that QED offer a small "race? crank pulley as well as a Europa T/C pump belt - I?ll enquire as to the crank pulley size but it does sound like they may have off the shelf components that will work - I also have to clear the tacho gear box so a big A section belt wouldn?t be ideal.
[email protected]
SJ Lambert
PostPost by: SJ Lambert » Sat Jan 27, 2018 3:54 am
The Cossie pulley on the motor has an OD of 96.3 with a 76mm diameter at the bottom of the "V? - a standard, I think, pulley from a Twin Cam Escort motor is OD 101.0, with a valley at 76.5, so not much of a difference for belt fitment.....
[email protected]
SJ Lambert
PostPost by: Foxie » Sat Jan 27, 2018 1:05 pm
ppnelan wrote:The standard water pump should be as reliable as any other part (?!) IF the fan belt is NOT overtightened.... The only problem is that if you do need to change it, it's a big job with the original front cover assembly.
:arrow: Matthew
Another suspect was an unbalanced metal fan mounted directly on the pulley flange :shock:
Always had an electric fan, and Burton cartridge fitted 15 years ago, so never a problem :)
68 Elan +2, 70 Elan +2s
PostPost by: SJ Lambert » Tue Jan 30, 2018 1:00 am
52f4d157-7747-4f93-b09f-139db54d5b04.jpeg and
2a1d4b6b-7dcb-4c6b-aacd-24fd1e3d13bd.jpeg and
[email protected]
SJ Lambert
PreviousNext
Users browsing this forum: checkrail and 17 guests
