Pop-up Headlamps
How? dont remember seeing a how to strip how to fix a pod section in the manual
Andy
Andy
- handi_andi
Andrew
If it's the shell of the pod that has a leak,there are many products on the market that will give you a fix...
If its the bellows (I've never done this) it may be possible to open the sphere with a fine slit,inspect/fix the bellows and re-glass the sphere back together...
First to fix the leak you have to find it...
I've aquired a couple of motors from a Volvo 480 which I'm intending to install in a +2. I've identified the various connections and can fabricate a bracket, but can anyone tell me where I can source the plastic rod ends in the UK, as shown in the earlier pictures?
Kevin
Kevin
- kevin
Kevin
Mail order companies like RS Components http://rswww.com
should do various connections.
Alternatively specialist companies like
http://www.springfixlinkages.com
Clive
Clive
1972 Elan Sprint FHC
- cliveyboy
I adapted ball joints from a windscreen wiper linkage assembly I sourced from a car breakers.
I think they came from a Vauxhall Astra, but most modern vehicles use similar joints. One advantage of them compared to the standard enineering stock item is that they are designed to be used outdoors on a vehicle without lubricatio. The disadvantage is that you may need to modify them to suit you application.
Ian Phillips
Ian Phillips
Elanman99 - Third Gear
