Lotus Elan
new fangled starter motors
PostPost by: Hamish Coutts » Wed Apr 05, 2006 3:04 pm
Absolutely on the button Sean :) .
Hamish Coutts
PostPost by: Dave_Newcastle » Sat Apr 08, 2006 9:23 am
This is an interesting thread which has caused me to think about solving my sticking starter motor problem.
I believe the sticking I experience to be because of teeth starting to wear on the flywheel - its only happened twice so far. However my car has been a poor starter for years which I think is because the lucas motor hasnt been spinning the engine fast enough.
So I am thinking of buying a new starter motor. I have some questions which I would be grateful if anyone could answer:
1 Is the Brise motor from Mattys a gear reduction type??
2 With the cog coming onto the flywheel teeth from the other side, will it overcome to any degree any tooth wear on the flywheel ring?
Dave (+2s 130)
Dave_Newcastle
PostPost by: Hamish Coutts » Sat Apr 08, 2006 12:49 pm
Dave,
To answer your questions.
1 Yes. I've just got mine and it's tiny compared the the Lucas starter.
2. Very probably.
Sounds like you've either got a lazy starter or it's out of alignment with the flywheel somehow. E.g. something between the starter mounting flange & the bellhousing.
Hamish.
Hamish Coutts
PostPost by: alaric » Sat Apr 08, 2006 1:30 pm
I second Hamish's response - the Brise fan club is running strong.
Re the teeth on the flywheel ring, I would guess that it depends on how much damage there is - if a whole tooth is gone then probably not. I presume the engine will always tend to come to a halt on the same bunches of teeth - probably 4 groups of them. You should be able to have a feel once the old starter is out.
The Brise is tiny as the solenoid is completely internal & not bolted onto the side.
Sean.
alaric
PostPost by: Hamish Coutts » Sat Apr 08, 2006 4:30 pm
Guys,
Got the damned Lucas starter out, finally. Had to take out the droplink bolt for the antiroll bar. Nothing is easy on a +2.
Brise popped in dead easy and is now bolted in place. Did a quick jury rig for the solenoid wire and the main power cable. It worked a treat.
One comment. The bendix on the Lucas had 10 teeth. The brise has 9 teeth but seems to work fine.
Just have to work out what the white wire does. (it fitted onto a spade terminal on the solenoid.)
Hamish Coutts
PostPost by: dougweall » Sat Apr 08, 2006 9:24 pm
Guys,
Just to add a few notes on this thread, I got my Brise starter a quite a while ago, without going into a lot of detail, I have had cause to wind my engine over quite a lot on the starter lately.
So when this last week I decided to haul the engine out, I had a look at the starter dog, with the bad treatment I have given it, believe me I expected the worst, but I have to say the starter dog shows no ill affects whatsoever.
So on the Brise front I am one happy bunny. As everyone has said a lot of cash but I am seeing it as worth it.
Doug.
dougweall
PostPost by: prloz » Sun Apr 09, 2006 12:48 pm
The Brise starter motor is tiny because there's no pre-engage mechanism. It's still an inertia type starter like the old Lucas !
Peter.
prloz
PostPost by: tdafforn » Fri Jun 30, 2006 2:27 pm
Well finally had enough of the Lotus starter and ordered a preengaged one from H&H ignition...
Works a bute...
One word of warning though, the top of the mounting plate fouled part of the engine block so I had to shave a few mm off it. Made the operation a bit of a pain, but the result was worth the pain!!
tdafforn
PostPost by: GrUmPyBoDgEr » Mon Jul 03, 2006 10:35 am
A question to you guys who have fitted the "Brise" pre-engaged starters to their Elans.
What is the position of the Solenoid when looking from the front of the car,
(e.g. 8 O'clock)?
Reason for asking is that on my Zetec set up, I have used a Ford pre-engaged starter & the Solenoid is at 6 O'clock. It's quite close to the handbrake cable (possible short circuit) & down there where it can get nice & wet.
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: rgh0 » Mon Jul 03, 2006 11:28 am
I use a Bosch pre-engage starter from a 70's Escort on my Elan and Plus 2. Cheap and effective and the solenoid hangs at the 6 O'clock postion as you describe. No problems with it ever getting wet in 20 years of use.
Clearance to the hand brake cable is just OK on my elan with a standard chassis. On my plus 2 with a Spyder chassis the cable is to close to the starter as the lower end of the handbrake cable on the spyder chassis is mounted a little higher.
I had to build an extension for the Plus 2 Spyder chassis that mounted through the original cable mounting point and moved the lower end of the cable about 40mm lower.
I also have a clamp rejoining the handbrake cable just next to the starter solenoid where a short through the cable melted it when it touched the main power cable teminal !!!!
You live and learn - I will send you photos if you like
regards
PostPost by: GrUmPyBoDgEr » Mon Jul 03, 2006 1:11 pm
Thanks Rohan,
it would appear that we are both using a similar starter motor.
Mine has been on the car for 4 years and used only in the dry without problems. The close proximity of the brake cable to the plus terminal seems to have worked for you & myself (up to now :lol: ) so I will forget about Brise alternatives & save the money for my retirement.
Thanks for the help we have all become accustomed to :D
GrUmPyBoDgEr
PostPost by: rgh0 » Tue Jul 04, 2006 10:24 am
If your worried put some tape or shrink sleeve on the brake cable in the region of the starter.
Be careful when removing the starter cable. The short on my plus 2 actually occured when I was removing the normally live starter power cable without disconnecting the battery (stupid I know but we all make mistakes). The spanner hit the brake cable as I turned the nut on the cable terminal. Thus leading to a large flash and melting of the brake cable.
This lead to me to looking at the installation and realising the brake cable on the plus 2 with a spyder chassis was actually rubbing on the solenoid case when the hand brake was on and I lowered the mount position.
PostPost by: GrUmPyBoDgEr » Tue Jul 04, 2006 1:09 pm
Rohan,
many thanks for the advice.
My Elan also has a Spyder tubular chassis & I think it is fairly safe to presume that in the area we are talking about, they must be identical.
The next time I'm under the car I will insulate the cable & take another look at the routing.
I'm going to do a G/box change in the not too distant future.
GrUmPyBoDgEr
Previous
