TR7 Pod Motor
Posted: Thu Sep 08, 2022 11:27 am
Is anyone using a TR7 headlamp pod motor ?. In operation my headlamps don't come up to the fully raised position however when switched off they continue to rise up fully open then return to fully closed. I've only just figured out why. When functioned to open the motor arm rotates approximately 150 degrees. When the lights are switched off the arm continues to rise from this position then returns to the fully closed position, 210 degrees of rotation. Is this "normal" for a TR7 motor or should it be 180/180 ?. I can see no reason for the reduced arc on the opening cycle. Before anyone mentions it, I know it's noisy, I have lubricated the bush but obviously haven't got to the correct location yet with the lubricant.
https://youtube.com/shorts/ksbBTngVO_g?feature=share
