Plus 2 Heater upgrade with a twist.
Hi There
I have a bit of a thing for heaters that work well. With my last plus 2 I refurbed the heater using a Fiesta matrix. With the one before that I fitted a Webasto Hi-Top (which I still have) down in the nosecone but with fuel prices where they are I do not want to press it back into service.
So this time round with my new pus 2 project car I have fitted the (new) matrix from a Fiesta (mk3 I think), but also the electric heater matrix from a mk7 Fiesta. I did not even know they had them, but they do. They provide instant heat but also improve emissions when used.
The units are (AFAIK) 800w which is a 66.7 amp draw at 12v.
I fitted it below the water matrix, and it actually works rather well, although I will have to wait until winter to really judge its effectiveness.
Pictures below
All the best
Berni
Pictures below
All the best
Berni
berni29 - Fourth Gear
" The units are (AFAIK) 800w which is a 66.7 amp draw at 12v. "
66.7 Amps ???
Hope you have a good alternator...
66.7 Amps ???
Good point!
Funnily enough the car did not come with an alternator, starter or battery, so I shall address that requirement soon enough.
In fact the electric heater will be on a separate switch and will in all probability only be used until the cars conventional heater reaches a similar temperature. Then I will switch it off.
Berni
Good point!
Berni
