Lotus Elan
Window motor upgrade
PostPost by: miked » Sun Jan 23, 2022 9:54 am
I know this has already been done but I wanted to have a go myself for the interest and satisfaction of doing it. From bench to car I realise that I need to cut the mounting studs back, too long. Did not dawn on me until putting in. However, pretty pleased with the outcome. Travel nice and fast on the bench window test with small motorcycle battery.
I am fitting the one touch control with current limit. Again worked good on the bench cutting off at a low current with no audible or visible straining.
Acid test is in the car and get some use. Quite a bit or work and thinking to get nice and close with the motor and a minimalistic adaptor plate. Also accuracy with 4 pick up points using basic workshop tools.
Can't wait to get out in the car when the weather picks up.
I have the running current and stall current from trial frame. Will measure again in car as the trial frame and glide strip was tighter. When the photo's are clicked upon the orientation corrects. Don't know why.
Mike :D
IMG_1653.JPG and
IMG_1649.JPG and
IMG_1648.JPG and
IMG_1647.JPG and
IMG_1637.JPG and
Elan S4 Zetec
Suzuki TC185
Suzuki Hustler T250
BMW rninet scrambler
Suzuki TC120R trailcat
Suzuki TC120 trailcat
Suzuki K15 Hillbilly
Suzuki TS185K
miked
PostPost by: nmauduit » Sun Jan 23, 2022 10:01 am
looking pretty good... would you share the specifics of the build (motors reference, control setup or required adjustements to the existing frame and loom, possibly including a photo of the frame without the motor etc.)?
S4SE 36/8198
PostPost by: miked » Sun Jan 23, 2022 10:38 am
If you look back on the link below with Mike's kit, the motor I used is suggested there as is the control module. Discussion on both. There are no frame mods. Picked up the three holes. Chopped the wheel mount coupling back to engage into nylon drive. See photo of trial fit.
Control module wiring is shown on module website. Pretty much drops in series with raise lower wires. Plus module has its own pos neg supply. Fits unders dash each side.
viewtopic.php?f=31&t=48955&p=358213#p358213
IMG_1638.JPG and
22DE8F33-9D25-45D4-84D5-4907821C5FBB.jpg and
Elan S4 Zetec
Suzuki TC185
Suzuki Hustler T250
Suzuki TS185K
miked
PostPost by: nmauduit » Sun Jan 23, 2022 2:14 pm
miked wrote:If you look back on the link below with Mike's kit, the motor I used is suggested there as is the control module.
thank you for the informations. I had read that thread, though remembered it as based on motors that may not be easy to source this side of the pond...
S4SE 36/8198
PostPost by: miked » Sun Jan 23, 2022 5:27 pm
I got these motors from that company in, I believe, Malaysia. No problem to UK.
Elan S4 Zetec
Suzuki TC185
Suzuki Hustler T250
Suzuki TS185K
miked
PostPost by: RAJ2628 » Sun Jan 23, 2022 6:08 pm
Great idea and the application of the adaptor plates looks well engineered. The addition if the cut out circuit is a good improvement too. Great pics and a good job Mike.
RAJ2628
First Gear
First Gear
PostPost by: geni » Mon Jan 24, 2022 3:56 pm
- oops! did I miss the address where these engines came from!
geni
PostPost by: miked » Mon Jan 24, 2022 5:34 pm
https://www.robotshop.com/uk/power-wind ... -left.html
Left motor fits right window and right motor fits left window.
Elan S4 Zetec
Suzuki TC185
Suzuki Hustler T250
Suzuki TS185K
miked
PostPost by: nmauduit » Mon Jan 24, 2022 5:46 pm
miked wrote:https://www.robotshop.com/uk/power-window-motor-with-coupling-left.html
thank you, that's closer from here ...
S4SE 36/8198
PostPost by: miked » Thu Feb 03, 2022 12:24 pm
Fitted to car and working with one touch modules. Nice and fast. One interesting point, I tried an old motor in the jury rigged frame on the bench with the one touch module. At limit it took over 10amps to stall and cut out at bottom limit. I had nipped the cable with the original style arrangement (pretty tight) and it ripped it apart so I only did it once.
I had been up and down and stalling top and bottom with the new motor. I was seeing an averge of 6.5 amps to shut the sensor down. Whislt mid way max current was about 4 to 5 amps on the new motor, the old one was 2 amps, probably due to the large permanent magents. However, a lot slower, but more to stall. I figure that running nearer the stall sensor current on the new motor allowed the circuit to chop off faster.
Anyway, I am happy, will carry on and see how they go during the year.
Elan S4 Zetec
Suzuki TC185
Suzuki Hustler T250
Suzuki TS185K
miked
PostPost by: miked » Thu Mar 31, 2022 7:07 am
Having been out for the first time in a good while I am please with the motors. Speed is great. The one touch is the icing on the cake though. Not having to dwell on the switches is great. Riding through town when you tend to lower the windows and then pick up speed as you leave allows a quick prod and up they go allowing you to concentrate on the driving.
:D
Elan S4 Zetec
Suzuki TC185
Suzuki Hustler T250
Suzuki TS185K
miked
