Steering column electrical connections.
Posted: Fri Sep 10, 2021 6:42 pm
Back at the new dash wiring after 6 months off.
1967 UK version S3 VIN 456208.
New wiring harness from the UK for a RHD S3. The harness has 8 bullet connectors for the steering column connection. They are:
Horn Button
Left Turn
Right Turn
Headlight Hi Beam
Headlight Low Beam
High Beam Indicator Light
Headlight Relay
Headlight Flasher
There are only 7 connectors on the harness coming from the steering column. None of the wiring colors match any wiring diagram I can find. I assume these connectors are:
Horn Button (single bullet)
Left Turn (single bullet)
Right Turn (single bullet)
Headlight High Beam (triple bullet)
Headlight Low Beam (triple bullet)
High Beam Indicator Light (triple bullet)
Ground wire (single bullet)
Can someone verify the power source for the steering column? It appears it may come from the flasher unit through a green wire. If so, does it connect to the triple bullet connector? Also, is the ground wire from the column wired separately to a ground source, and is it's only purpose to connect the horn button to ground?
Also, is the Headlight Relay connector the power source for the headlights?
Horn Button
Left Turn
Right Turn
Headlight Hi Beam
Headlight Low Beam
Headlight Relay
Headlight Flasher
