Ignition switch removal
Hello,
Quick question - could someone tell me how the ignition switch is held in the column mounted lock on a Plus2 S/130? Is there some sort of grub screw holding it in?
Also can it be removed without dropping the column/pulling the dash etc?
Robbie
Robbie
Not sure if it is the same as the 2 Seater (Baby ) Elan, but there is a plastic cap on the rear of the column mounted switch which snaps in place & there may be a screw that holds the switch to the column body. Picture below:
My Sprint does not have any screw or Grub Screw holding the SA157 ignition switch in place.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Thanks Phil, I do have a plastic cap but it doesn't stay in place. I think there must be a bit broken on it. Anyway the switch has never fallen out so something must be holding it in there. When the new switch arrives I'll find out for sure...
