Voltage drop
and the older copper is most likely of superior quality, over new.
the connections do take the abuse, also from vibration
every time a current is applied, there is (albeit minor) arching which leads to carbon deposits and loss
further, if you have chafing (not of the undies)
Love your Mother
Earth
Love your Mother
Earth
My next try would be the ground (earth) in the boot, after all, its a freebie.
RL
RL
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Problem solved.. I spent a few hours this morning adding a relay for the horn. Makes a big difference. Now the horn is LOUD ! I now understand grounding the horn directly with a relay, versus through the steering column is the way to go. However I'm still not sure iif my voltage drop is normal. Thanks for the help as always Chris
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Maybe you still need to bypass Ignition Switch to prove if there is resistance.
- alan.barker
