Tips on removing dash mounted ignition switch?
USA64 wrote:So I could have picked that wrench up instead of scrambling for something to bat it off with? Good to know.
NO! That's not the same situation, you dropped a low resistance object across terminals capable of delivering hundreds of amps. The spanner/wrench would get RED HOT in moments & if you had lifted it by hand you would have burned your hand. THe 12v electricity would not have harmed you much, just a tingling, but the heated wrench would burn you.
You can MELT steel objects by shorting them across a car battery.
billwill wrote:RogerFrench wrote:I find it easier on the S3 to remove the washer/ wiper switch first.
I think that only applies to LH drive cars.
Don't know, mine is RHD!
RogerFrench - Fourth Gear
RogerFrench wrote:billwill wrote:RogerFrench wrote:I find it easier on the S3 to remove the washer/ wiper switch first.
Ooops, yes, you are right. For some strange reason I was thinking the ignition switch was bottom right (on UK cars), but of course that is the headlight vacuum lifter there.
Come from not driving the Elan this year methinks.
.. Puts Dunces cap on and leaves..
Resurrecting an old thread...
Stupid question time: Is the lock nut that secures the ignition switch to the dash normally threaded or left hand threaded? My non-starting, no lights, no power at the coil issue has brought me to testing the ignition switch. I cannot remove the lock nut to remove the ignition switch. I created a removal tool using a thin bar of aluminum, but no luck. The bar bent. I tapped on the nut using a screwdriver and hammer, but it didn't move. It's either on really tightly, cross threaded, or has left hand threads. I'm assuming it works the good old fashioned, left-loosey-righty-tighty way. Please advise.
-Brad
-Brad
'69 Elan S4 DHC, 07 Exige S, 04 911 40th Anniversary, 86 Scirocco 16v, 81 Callaway Scirocco, '76 Scout II
Kip - New-tral
Thanks for confirming. The homemade tool from a copper or metal pipe is my next move. The aluminum/aluminium bar failed miserably. If the homemade tool fails, I'll order from Moss.
-Brad
-Brad
Kip - New-tral
Hi Phil
Brad said it was in tight, so maybe approaching 100 lb ft but if your copper pipe homemade tool works OK then perhaps that is the way to go. It just surprises me that you can make a tool that is strong enough using two little copper tabs. Live and learn.
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
