instrument lights
I have opened my tach and speedometer because of a powder being on the inside of the glass. The powder proved to be the reflective paint on the inside of the housing which casts an indirect light on the face. I thought it might be of use to the less intrepid/foolish who do not open the works to see what was inside. In particular note that the light bulbs insert into a tube which approaches but does not connect to the lens. The final connection is made by a short length of white, rubber, tube which fits into the socket tube and over the lens back. I found one intact, petrified tube on the ignition lens, and one perished, broken tube on the high-beam lens. The ignition lens was completely covered on the inside so no light could get through. I wonder how much cursing of the electrics might have ensued when the light stubbornly refused to work after I had replaced the entire harness?
We are supposed to be having fun, are we not?
- USA64
This is helpful, many thanks.
I've become a bit of a fan of Serge Sleurs' restoration of his Europa, as shown in his many YouTube videos. One deals with the speedo & tacho. May be of interest to others...
[url]https://youtu.be/UyBWbNYvxhg
[/url]
All the best
Ned
[/url]
All the best
Ned
+2S 1969 50/2283
NedK - Second Gear
To add further, it seems that the inside is galvanized. This results in the paint (Rustoleum self-priming spray can) not adhering well. I think if I do it over, and I may, I will use a water-based primer (Zinzer Bullseye) first.
- USA64
If the can is galvanized steel, try muratic acid (usually used in ceramic tile cleaners) to etch the galvanizing, neutralize with baking soda and then prime for paint.
