Lucas C40L Generator Bearing
Hi All,
I was refurbishing my Lucas Generator (C40L) and noticed that the bearing is binding at one spot. I decided to replace it. Does anyone know a supplier in the US for these bearings?
Thanks in advance,
Jay S.
Thanks in advance,
Jay S.
Jay S.
1972 Federal Sprint, Colorado Orange/White
2005 Elise, sold
1988 Evante 140TC, sold
2005 Elise, sold
- Evante
I imagine you mean the Oil Lite Bush at the rear.
You can use the parts for a C40 which is on many British Cars e.g. MGB or Austin or Ford.
At Moss for example.
- alan.barker
Evante wrote:I was refurbishing my Lucas Generator (C40L) and noticed that the bearing is binding at one spot
Something has probably gone wrong with reassembly if it's binding. A worn rear oilite bearing won't cause binding. If required the front roller bearing is just a standard roller type readily available for industrial bearing suppliers. Not normal for them to cause binding either even if worn.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Are you trying to rotate it with the brushes installed or without? The pressure on the comm can make rotation feel a bit lumpy.
- nigelrbfurness
Attached is a pdf of the Lucas/Girling/CAV catalog of bits for Ford from 1965, that includes the C40L generator and the part numbers for the bits inside. May be helpful in finding your bearing.
EDIT - pdf was too large, so have attached a screenshot of the correct section.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
SENC wrote:EDIT - pdf was too large, so have attached a screenshot of the correct section.
Hi, I would be interested in taking a look into that PDF, at least to see the full page ... I did search for that PDF but did not find it (other than on those obscure web sites asking for credit card details ), could you pass it to me ?
1964 S1 (at paint shop)
1967 S3 DHC
1969 S4 FHC (at BB's home)
1967 S3 DHC
- gherlt
Gherit - I recently shared it to be put in the download section of the USA7s new site:
https://usa7s.net/ips/files/category/28-ecu-electrical/
You should be able to find and download both 1965 and1969 catalogs at that site.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
Thanks !
1967 S3 DHC
1967 S3 DHC
- gherlt
