new plug lead?
HI, Having just bought a Synchrometer and Gunson Colourtune, after using them as per instructions, my Plus 2 would not accelerate past 2'500 rpm without a really bad misfire which was I'm sure electrical.
Thought I would use the Colourtune again and using it on no.2 cylinder there was a crack from the plug well and using a screwdriver on the mixture screw another crack/short.
It idles fine, but can't give it a proper road test because of the misfire.
I have standard leads, new NGK's and new dizzy cap. Thanks for suggestions. John.
- checkrail
Hi John,
on Webers?
What amount of advance are you using?
how was it running prior to your changes?
Iain
on Webers?
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
sprintsoft wrote:Hi John,
on Webers?
Iain
This issue may be related to John's earlier problems getting the engine running....
viewtopic.php?f=38&t=47027
S4 DHC
S4 DHC
- oldelanman
HI Iain, It's a S130 on Webers with QED 420 cams fitted by previous owner, according to the paperwork I have quote 'timing about 24 degrees @ 2500 rpm slightly retarded'...
It was running fine before all the Accuspark / ignition problems, please see all my previous posts.
I have ordered a new set of plug leads.
Regards John
Regards John
- checkrail
Hi John,
Ok thanks I’m up to speed now, I just read the trail that oldelanman gave us.
Your issue seems to start on Jun 20th when you wrote:
“Hi, Whilst trying to sort the tickover on my \webers I foolishly left the ignition on, resulting in a non starter'....”
You don’t sound fully confident that issue is fixed yet? I think you need a second pair of eyes on the problem, a competent auto electrician should be able to diagnose and recommend a fix to allow you to move on.
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
