Elan Sprint 123 Bluetooth Distributor for Weber engine
• Page 3 of 3 • 1, 2, 3
TeeJay wrote:Took the Lotus out.
So the question is does the new Distributor technology improve on the old?
Hope to hear more comments. Friend with XKE loves it, also for the security.
Love your Mother
Earth
Love your Mother
Earth
h20hamelan - Fourth Gear
nmauduit wrote:Peter +2 wrote:Spurned on by this post I too have acquired a 123 Bluetooth distributor and about fit. I have not decided on coil yet, but does any know why 123 appear to recommend a 3ohm coil?
Peter
I've been using a red Bosch "performance" coil (1.8 Ohms, supposedly 33000V spark - no ballast) since installation 5-6 years ago, no issue so far (I understand if you go below 1.8 Ohm you may pullm too much current and risk damaging the circuit)
Thanks I will stick with the 3 ohm one for now.
Needless to say my install has not gone to plan so giving up for the night and will resume tomorrow. I plan to use the Escort curve but would like to check I have understood the install instructions correctly. In order to set the 123 dizzy in the correct position using the green light, should the engine be positioned at TDC or 12 BTDC?
Thanks in advance.
Peter
1968 +2 BRM
- Peter +2
Peter +2 wrote:[In order to set the 123 dizzy in the correct position using the green light, should the engine be positioned at TDC or 12 BTDC?
I prefer to set it to zero TDC , so that the programmed curved is the actual ignition curve (but you also could set it 12 btdc of whatever and deduce that from your programmed curve to the same effect)
S4SE 36/8198
nmauduit - Coveted Fifth Gear
That’s great. I thought TDC would be fine so will stick with that. The main thing is I can now rule this out as a reason for the no start. I will have another go tomorrow and hopefully the engine will start.
I installed a 123 on my old Mercedes a few years back and the car started on the first turn of the key. I wish things were like that when I mess with the Plus 2.
1968 +2 BRM
- Peter +2
Dizzy was 180degrees + a spline or two out. All running fine using the Escort curve for the time being.
Thanks for the help and info.
Peter
Peter
1968 +2 BRM
- Peter +2
Peter, good to hear that you are sorted.
I also found the Escort Curve to be more suitable to date, but I am also sure that when my engine is run in, it will be possible to increase the advance above the 26 degrees at 2400RPM it’s currently set at. Note this being for a Road car.
Trevor
1968 Elan +2 50/0173
TeeJay - Fourth Gear
