Tachometer
Posted: Sat May 23, 2020 12:24 pm
Hello all, just finishing off a restoration on an S4, have driven to and from the technical control and a couple of small
local runs to show up any faults, so far nothing serious but one that has me a little stuck, the tacho does not work,
from very first start up in the garage to first run out nothing, then on the way back from the technical control it suddenly started working, got home stopped the engine started up again tacho does not work again a few days later
same thing happened went for a small run about a half hour and along the way tacho started working got home switched off, started up again tacho didn't work has happened 3 times now, strange problem any ideas,
thanks Geoff.
thanks Geoff.
