Headlamp pull switch removal
Mon May 11, 2020 4:20 pm
by djb222
Removed all the switches lights etc from the dash today, the cigar lighter was a pain but came out ok but the ceramic heat shield was broken so may need to source another, but one unit is proving to be a right B@$*^%d to remove... the head lamp vacuum pull. I may have twisted the push bar but if I can get it out I think I can fix it. The tabs at the back do not want to budge. Any ideas?? Please.
Re: Headlamp pull switch removal
Mon May 11, 2020 4:41 pm
Spring-loaded "button" in the knob...
Edit Looks like you've removed the knob?
Mon May 11, 2020 4:46 pm
by djb222
No the knob is still there. Thanks, thought there was an easy answer, wouldn't mind but I've removed a fair few like this in the past...... just put it down to age.
Tue May 12, 2020 5:59 am
There is a small hole in the side of the knob. Slide small dia rod down inside the hole to the bottom and push. This will release the spring loaded button at the bottom.
Tue May 12, 2020 9:38 am
by djb222
Thanks.... Success, Black Knob removed and yes I'd twisted the shaft so it wouldn't slide back and forth. Managed to dismantle it and straighten the shaft and will reassemble tomorrow. These head lamp pull switches are so hard to find, found a really rusty one for £80 and one of the usual suspects is selling just the black Knob for £40 +vat
Tue May 12, 2020 10:18 am
You can buy the black plastic knob from "Rimmer Bros UK" it's Triumph Herald and much cheaper
Tue May 12, 2020 11:27 am
by jono
DJB, do you need a replacement vaccum switch unit as I have one (sans knob).
PM if interested
Tue May 12, 2020 11:33 am
by elated
The Triumph knob is identical but its icon differs
Gordon
Tue May 12, 2020 12:00 pm
by djb222
Thanks guys.
Jono, I've managed to put it back together, so it should be ok...I'll be in touch if it doesn't work...Thanks.
Tue May 12, 2020 12:12 pm
elated wrote:The Triumph knob is identical but its icon differs
Gordon
I'm sure if you didn't tell someone they wouldn't notice. Unless they are wearing an Anorak
Got one on my sprint no problem
