Oil Pressure Sender
• Page 1 of 4 • 1, 2, 3, 4
My 1970 Plus 2S has a Smiths electrical gauge that reads 0-60psi. I need a new sender but can't find a 0-60psi one. I understand from some other threads these might be hard to get now. A quick search shows 0-100psi ones are plentiful.
Can anyone confirm that the sender thread size is 1/8" NPT? That seems to be to most common non-metric thread size for senders, but confirmation would be good.
Also, if I understand how these things work correctly, the sender will, for a given pressure, send a resistance reading that will cause the needle in the gauge to move a certain amount but I don't know if fitting a 0-100psi sender will cause my existing gauge to read correctly.
So, for example if a certain oil pressure causes a 0-100psi sender to send a resistance that would move the needle to the halfway point, that would be 50psi on a 0-100 gauge and presumably 30psi on my gauge.
have I understood this correctly? Any clarification or comments would be appreciated.
Andy
Andy
Sept 1970 Plus 2S, KOO38J Glacier Blue, 50/2432 (was Carnival Red)
- Andy Hamblin
Andy, this thread has some information that might help
viewtopic.php?f=38&t=37144
Nissonger in the US lists a 0 to 60 psi sender, but unfortunately does not state the thread size
http://www.nisonger.com/XKE%20Replacement%20Gauge.htm
Same deal for Moss Motors, although they provide the Jaguar models that appear to have the 0 to 60 psi gauge range.
https://mossmotors.com/transducer-oil-pressure
In general it is my understanding that yes, the sender and the gauge range have to be matched for accuracy.
HTH
Stu
HTH
Stu
Stu
1969 Plus 2 Federal LHD
Thanks Stu, great info. Looks like it won't be straightforward!
- Andy Hamblin
Andy
You need a new sender , do you have the old one ?
It may be repairable...
Or, contact Gavin Roberts of Caerbont Automotive Instruents - he is the Smiths agent in the UK.
[email protected]
[email protected]
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
john.p.clegg wrote:Andy
That's the problem John, I think the old one is the wrong spec (0-100psi range).
But, on the offchance it is the correct one just malfunctioning, who can rebuild them and does it make economic sense to do so?
- Andy Hamblin
HCA wrote:Or, contact Gavin Roberts of Caerbont Automotive Instruents - he is the Smiths agent in the UK.
[email protected]" target="_blank
Great, I will do that. Many thanks.
- Andy Hamblin
Andy Hamblin wrote:john.p.clegg wrote:Andy
You should be able to tell by the part number stamping , /06 is 60 psi , /10 is 100psi.
SJSportscars list what should be the correct oil sender unit:-
https://www.sjsportscars.com/parts-and- ... 6E0003.htm
Alan.
Alan.
'71 +2 S130/ 5speed Type9.
- alanr
alanr wrote:SJSportscars list what should be the correct oil sender unit:-
Alan.
Thanks Alan, I'll check that out on Monday when they are open. I suspect it might be a 0-100psi one, looking at the very broad fitment list, but will find out and report back.
- Andy Hamblin
Alan.
Right, so I phoned SJ Sportscars and asked them if the sender they have is 0-60psi or 0-100psi. The gentleman said he didn't know but it was the right one for a Plus 2 (although we hadn't discussed spec/year etc).
I explained that the gauge was 0-60psi but that senders for that seemed difficult to get in the right fitting, so i wanted to be sure the one they are listing was correct for my car and wasn't a 0-100psi one .He said he didn't know. I asked how we could find out. He said we can't find out, so if that is important to me I should look elsewhere.
I think I will, and for everything else I might need as well..
- Andy Hamblin
If " it's the right one for a Plus2 " , buy it,fit it and return for full refund if not correct..
If correct , post here?
jOHN
jOHN
