Headlight vacuum system
My 72 +2 130S was partially disassembled on purchase. I am now looking the the headlight vacuum system. The bits I have are shown in the attached photo.
I am assuming that the broken Tee piece on the end of the plastic pipe should be connected to the manifold and the chassis tank with the rubber pipe connecting to the headlamp vacuum cylinder. Is that correct?
My Lotus manual shows a completely different solenoid valve, so again I’m assuming it’s a later part? Where and how is this solenoid located? It appears to have no fixings and looks like it may have been held by some adhesive.
Elan +2
Elise mk 1
Elise mk 1
- Donels
This is where it should be mounted:
Ted Taylor may have an original one available:
Check here - http://www.taylormadeclassiccars.com/partsselecttype/bodytypeparts.html
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
