condenser for distributor 23D
Hallo!
I do not see any condenser on my brand new distributor 23D.
do I have to wire and external one? where? I do not see any hole where screw the body of the condenser?
do I have to drill the body?
is this condenser built in? ... so I do not need any extra part?
ciao a tutti
Paolo
- lotusbzz
Hi Paolo. You only need a condenser if you are using points. It would be screwed to the base plate under the distributor cap next to the points/contact breaker. It is possible you have electronic ignition under the distributor cap and you will not then need points and condenser. Cheers, Lyn
- Lyn7
It's just a short cylinder bolted to the plate at one of its ends and a wire coming out of the other end joining the contact breaker spring on an insulator and the wire to the spade for the coil.
Meg
lotusbzz wrote:Found!
Officially I can tell you that my Lucas 23D fits its own condenser inside!
Have a nice week end
Paolo
Thank you, Paolo, it's unusual for people to tell us the final result!
Meg
