Plus 2 wiring loom routing
I?m putting my Plus 2 back together (bought in boxes), can anyone confirm the routing of the rear loom. It looks to me like it either runs through the body of the car along the floor to the left of the driver?s seat or perhaps along the top of the tunnel under the central console. I should add it?s a right hand drive, S130
- NYK
On my early Plus 2 it runs on the floor alongside the passenger (left side) door sill, up behind the trim panel beside the rear seat, past the seat belt unit and over the top by the top of the shock mounting, then it splits and one section goes to the tank sender and the other continues around the inside of the left wing to the left rear light then across to the number plate lights finally ending at the right hand rear lamp. In amongst this are aerial and speaker wires and interior lamps wires that come out of the harness at the appropriate points. The front of the harness joins the dashboard and front harnesses behind the glove box.
- Bigbaldybloke
Just for another data-point, my car is 'mostly early,' a transition-period car but not an S, and is a federal LHD, and the loom runs along the left side as BBB describes above.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
